Front spring replacement
Old 08-11-2014, 02:06 PM
JPMallory's Avatar
JPMallory
JPMallory is offline
I'm planning on replacing my front springs and shocks very soon. I've never done this before. Is there anything I should look out for/be aware of before I do this?
Old 08-12-2014, 08:48 PM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
Not sure where you're planning on getting your Springs but hopefully they will come with the bushings installed. You'll need new shackle bolts. Make sure they fit the bushings before trying to install the springs. Sometimes you may have to have the bushings reamed to fit the bolts. Also check the hanger bars for wear. 1953-56 Ford F-100 Spring Hanger Bar, Front Outie Notch, Replacement
You'll also want to pick up new U Bolts, nuts and a few straight axle alignment shims. Don't forget to get the ole Iffy realigned after you complete the Job.
Shocks are pretty straight forward UNLESS you're using dropped springs. If your dropping the front end you'll need to get shocks that match the drop or reposition the shock mounts to compensate for the drop.
Old 08-12-2014, 09:01 PM
raytasch's Avatar
raytasch
raytasch is offline
Believe Nothing
Not knowing what your experience is, be sure to use jack stands under the frame. Make certain the jack stands are on a solid surface. If the truck were to fall, it could make for a bad day.
Old 08-13-2014, 12:33 AM
jimcar-9's Avatar
jimcar-9
jimcar-9 is offline
Well here you have my work documented so far
it´s both on rear and front suspension, bushing replacement, reaming etc
DinnerHill SpeedShop: Front axle
DinnerHill SpeedShop: Front suspension
DinnerHill SpeedShop: Leaf springs
DinnerHill SpeedShop: Rear suspension
Let me know if you have any questions
Old 08-13-2014, 06:47 AM
bjmayberry2
Lookin Good!
Old 08-13-2014, 09:03 AM
JPMallory's Avatar
JPMallory
Thanks. I bought the springs from macs, and they should be here today. Unfortunately the bushings and pins are on backorder.
I'm going stock ride height, so I should be fine on the shocks.
SpacePirate77
38
08-21-2015 11:31 PM
themdgx
1983 - 2012 Ranger & B-Series
13
12-16-2012 10:21 AM
RTFMAce
1999 to 2016 Super Duty
05-07-2011 04:46 PM
blindboyth
10-18-2006 02:43 PM
Ford_F-250_1990
10-17-2006 08:22 PM
Quick Reply: Front spring replacement
