Sponsored by: Real Truck
04 E-350 NO START
Old Aug 12, 2014 | 09:57 AM
fyrmech14's Avatar
fyrmech14
04 E-350 NO START
i have an 04 e-350 that won't start ran fine till the other day when i had a wheel bearing fail on me and had to get it towed on a rollback it drove right up on the rollback and when it was brought to my shop we tried to crank it and nothing!!!!!! put the code reader on it and came up with a p1233 fuel pump driver module disabled or offline so i called ford and ordered that part and after $160.00 later still did not fix it and i need help anything will help!!!!!!!!
Old Aug 12, 2014 | 10:03 AM
David7.3's Avatar
David7.3
Check the fuel pump reset switch, When your truck was tied down on the wrecker the bounces amplify. so a pothole to the tow truck is a curb to your van, the fuel safety switch tripped. I believe on the 04 is on the passenger kick panel, or you will see a hole about 2" reach in and press the red button, should hear it click.
Old Aug 12, 2014 | 10:24 AM
fyrmech14's Avatar
fyrmech14
thank you so much!!!!!!! that fixed it
chorepail
2004 - 2008 F150
Mar 11, 2014 08:55 AM
Mjpolchies
2004 - 2008 F150
Aug 25, 2013 06:32 PM
billy1269
Jun 20, 2006 07:18 PM
