Timing Chain Replacement
Old Jul 12, 2003 | 12:03 AM
MCalvin460CI's Avatar
MCalvin460CI
I JUST WANTED TO KNOW WHATS INVOLVED IN CHANGING THE TIMING CHAIN ON A 1996 FORD EXPLORER WITH A 4.0 V6. IT HAS 150,000 MILES SO ITS PROBABLY DUE. WHAT ELSE SHOULD I DO WHILE CHANGING THIS? WHAT NEEDS TO BE DONE AT 150,000 MILES? ALSO WHEN ITS IDLING IT MAKES SOME SORT OF RATTLING NOISE THAT SOUNDS LIKE ITS COMING FROM THE ENGINE. WHAT COULD THAT BE? THANKS
Old Jul 13, 2003 | 04:42 PM
CNTHOR's Avatar
CNTHOR
The dealer told me that the timing chain doesn't ever need to be changed. They are supposed to be very strong and do not stretch
Old Jul 31, 2003 | 02:53 AM
rrjwk's Avatar
rrjwk
Hello. do you have a 4.0 pushrod or a 4.0 ohc engine? If you have a pushrod engine the timing chain should be just fine until it's time to rebuild the engine. I have never seen one break, even on engines with over 200,000 miles. If you have a 4.0 ohc engine (I think they started in 98 so this shouldn't be the case) the timing chain tensioners have been in what's called an "open recall" by ford. The noise comes from the timing chain being loose caused by a fai;ty tensioner.
Old Jul 31, 2003 | 07:38 AM
stubborn1's Avatar
stubborn1
The rattling noise is fairly common on the 4.0 OHV. Sometimes mine will sound like there is a bunch of marbles bouncing around or like a diesel engine at idle. I've talked to two mechanics who said that it is pretty common for this engine.
Old Aug 1, 2003 | 01:08 AM
Ponyracer's Avatar
Ponyracer
Yes it is real common but easy to fix and not the timing chain. I had the same trouble and after many attempts to repair by our tune up guys who meant well, I found through this site that the mass air sensor gets covered with dirt and oil causing it to give an incorrect reading to the computer. All you have to do is a search for the repair procedures on this site and clean your mass air. Rattling will be gone.
Old Nov 9, 2003 | 05:23 PM
sokar311's Avatar
sokar311
Hi, I want to know how to adjust the timing of the timing chains on a explorer 98 xlt 4x2.
I would realy appreciate some help! anything
Old Nov 9, 2003 | 07:36 PM
Majisto's Avatar
Majisto
The SOHC V-6 motor began in 1997, and had the timing chain tensioner rattle until the 2000 model year. The chain itself wasn't bad, but the tensioners were. Timing chains should never need to be replaced. The only reason you replace belts is because they stretch and bend.
The OHV rattles because of the wrist pins in the motor, NOT the timing chain. The wrist pins were changed (I thought this was 1999, but maybe earlier) because of emissions reasons, and they will cause a marble rattling noise. It could also be your lower intake manifold needed to be tightened. It may even be an exhaust leak...but it will 99% of the time be something other than the chain.
Old Nov 9, 2003 | 10:29 PM
sokar311's Avatar
sokar311
Thanks, but sorry if you missunderstood me, i already have my new timing chain kit, the chains, tensioner, etc.., and i would really like to know how to set them correctly because i installed them and the engine has a little failure, if you or someone could tell me with detail how to install them on my explorer V6 xlt 4x2 SOCH engine, i would really apreciate it.
Thanks in advance.
DairyFarmer5
Mar 9, 2016 10:04 PM
dg53
All Things Towing
15
Feb 10, 2016 12:07 PM
Michaelshawnbradford
1983 - 2012 Ranger & B-Series
May 8, 2015 08:19 AM
Macmathews
Jan 28, 2015 12:58 PM
SoYouCanSuperDuty
Modular V10 (6.8l)
59
Jun 17, 2014 09:22 PM
