1978 - 1996 Big Bronco
Bronco Stalling
Old Jul 11, 2003 | 11:45 PM
mds01's Avatar
mds01
Question Bronco Stalling
When I am backing up and I turn the wheel as far as she will go to the right or left my bronco will stall. Does anyone have an idea why this happens and what I can do to fix it, I havent really noticed it happening when I am going forwards but I think it has once or twice, as I said seems to only stall when I cut the wheel hard to the left or right. Thanks for any help!!
Old Jul 12, 2003 | 01:53 PM
steve83's Avatar
steve83
Bronco Stalling
Does it stall if you're in Neutral/Park, or only if you try to roll?
Old Jul 12, 2003 | 08:14 PM
Copper93's Avatar
Copper93
Bronco Stalling
The power steering pump has a pressure sensor that could be going or already went bad. It cuts pressure during turns so the engine doesn't stall. I'd check sensor. I couldn't tell you the exact location but I'd check it out.
Old Jul 13, 2003 | 03:06 PM
steve83's Avatar
steve83
Bronco Stalling
The PSP sensor has no effect on hydraulic pressure - it only signals the EEC to raise the idle if the TPS is at idle position when the pressure gets high. If you're driving, it has no effect. It's installed in the high-pressure line between the pump & the steering box and has 2 wires.
Old Jul 14, 2003 | 04:38 PM
Copper93's Avatar
Copper93
Bronco Stalling
I misspoke about the switch cutting pressure. Your right, but if the switch is not working it will cause idle problems or stalls if the switch is stuck open and the pump is drawing on the engine at an idle.
Old Jul 15, 2003 | 09:55 AM
mds01's Avatar
mds01
Bronco Stalling
She only stalls when Im in reverse and backing up, shes fine in park and neutral.
Old Jul 15, 2003 | 10:12 AM
steve83's Avatar
steve83
Bronco Stalling
Could be a transmission problem then. Have you specifically tried leaving it in Park, keeping your foot OFF the gas, and turning the steering wheel?
Old Jul 18, 2003 | 10:59 AM
mds01's Avatar
mds01
Bronco Stalling
Ok, foot off gas, left in park, turn whole way to the right makes a squeking chirping?? type sound, same sound when I turn her to the left and also when I leave her in neutral and do the same thing, she doesnt stall like when Im backing up. Power steering is full of fluid, also could someone describe again where I could find that sensor, right now I know where the power steering pump is, if someone could direct me from there and thanks for all your help!!!!
Old Jul 19, 2003 | 01:15 AM
steve83's Avatar
steve83
Bronco Stalling
Your problem is in the transmission, or in the carb.
The PSP is on the high-pressure line from the pump; the line on the side with a metal fitting that swivels.
Old Jul 19, 2003 | 04:31 PM
mds01's Avatar
mds01
Bronco Stalling
Thanks for your help and the directions, Ill let you know what i find out!
mds01
Aug 12, 2022 08:50 AM
jrockdiddy
13
Mar 21, 2016 07:39 PM
Wingman69
General Automotive Discussion
Jul 19, 2015 02:40 PM
animal2b
Mar 4, 2015 04:19 PM
Zukster
May 5, 2003 12:46 PM
