Fuel door
Old Aug 11, 2014 | 01:33 PM
Jo31422's Avatar
Jo31422
Fuel door
I have a 2010 ford f-150. My fuel door swings loose and the cover came off on the highway. Any idea on where I can get another one? I need to replace the whole thing. Any help is greatly appreciated.
Old Aug 12, 2014 | 11:44 PM
tvsjr's Avatar
tvsjr
The loose swing is probably an issue with the spring/plastic pin. I just had to fix this on my 09, and followed the instructions here (apologies for linking to That Other Site...):
09-13 fuel door cover spring repair - F150online Forums
In my case, the hinge/pin assembly slid up about an inch, which caused the door to not fully open or close. If your door is completely loose, it's possible the spring broke or the plastic fractured. This will likely necessitate replacement.
Tasca and others sell the fuel door. Appears the part number is 9L3Z-99405A26-AA. Unfortunately, this is a paint-to-match item... you'll need to find someone who can paint it for you. The way Ford attached the door is silly... surprised more people don't complain about it.
You could also look at one of the billet aluminum doors, if that look is for you.
Old Aug 20, 2014 | 08:16 AM
extremejv's Avatar
extremejv
Same thing...
I had the same thing happen to me about a month ago. I ended up getting the part from my local dealer (about $100) and replacing it myself.
I used this guys video to help me:
(I did not do his "upgrade")
But I will say that getting the old one out was kind of a beating. After fighting with it for a while I just started cutting little pieces out of it till I could get it out. The new one slipped in pretty easy.
I can post some pics of what i had to do to get the old one out if you want.
Good luck!
Wbruiser2
1997 - 2003 F150
Sep 27, 2018 05:22 AM
BigNiner19
2004 - 2008 F150
May 17, 2009 11:52 PM
fx4me
2004 - 2008 F150
Apr 21, 2006 10:30 AM
cbsaf
2004 - 2008 F150
Jun 29, 2005 07:15 AM
fredidog
2004 - 2008 F150
Jun 3, 2004 06:05 AM
