where to start
Old Aug 11, 2014 | 12:25 PM
Maltman's Avatar
Maltman
where to start
noticed yesterday that the front drivers side of my truck is sagging-measured and it is about 3/4" lower. I visually inspected and noticed no cracks in leafs and all bushings, while worn, are all intact as well. any ideas on what to check next? I also have a popping sound turning left while the suspension cycles-on the same side...king pins??
thanks in advance fellers
Old Aug 11, 2014 | 02:57 PM
cyclone-429's Avatar
cyclone-429
King pins would be my first guess for the noise, but not the sag. Old leaf springs would probably be the cause.
Old Aug 11, 2014 | 06:04 PM
Damifiknow's Avatar
Damifiknow
Definitely king pins for the noise. Same thing happened to me thought it was springs. Jack up truck, heat with torch while you have someone turn wheel left to right if you cant get grease to go in zerks. Then grease. Worked for me but mine weren't worn just caked with dirt and dried grease. As for lean??? Worn springs?
Old Aug 11, 2014 | 10:18 PM
GB SISSON's Avatar
GB SISSON
I'n not exactly sue, but I think I added 2 to the left front spring pack of my f350. Without looking I think I have seven on one side and 9 on the other.Now it sits very level. I save and collect leaf springs for that purpose. I think the ones I added were from the rear of an international 1/2 ton I encountered at a wrecking yard. Someone had taken the axle and the leaf packs were sitting in the dirt. 5 bucks got the pair at the front desk......
Old Aug 14, 2014 | 07:53 PM
2losteve's Avatar
2losteve
You might want to check your rear springs also. On my '56, I had a similar situation and spent a lot of time on the front suspension looking for the problem. On someone else's suggestion I removed the rear springs and found one to have a different arch than the other. Replaced both MAIN leaves and problem was solved.
These trucks have sometimes (or many times) been overloaded, while the front carries a fairly consistent load.
Steve
Old Aug 14, 2014 | 08:28 PM
Maltman's Avatar
Maltman
thanks for all the replies, I will get under the truck this weekend and see what I come up with
Joe
Old Aug 17, 2014 | 11:36 AM
Maltman's Avatar
Maltman
both sides of kingpins worn out-long story short, its time to go through front end this winter...think that the drivers from leafs are worn/sagging, will figure that out when apart and look into rear springs as well, thank you for the help.
Joe
jlmotox
1997 - 2003 F150
Apr 20, 2009 08:22 PM
BAJI26
Dec 25, 2008 05:52 PM
goatdriver
2004 - 2008 F150
Sep 13, 2008 08:48 AM
fordblue_ca
Sep 30, 2003 02:44 PM
TallPaul
Aug 24, 2001 02:59 PM
