Changing engines
Old Aug 9, 2014 | 10:00 PM
lorts's Avatar
lorts
Changing engines
Hey guys I bought a 04 f250 had 350kms on it the head gasket was leaking but when I pulled apart there was water damage in the cylinder, so I'm now trying to find a low mileage engine to put in there are some out there but I can get a 06 engine for the same price. Now since the newer 6L are better than the old ones would it be possible to make it work in a 04 chassis electrical wise.
Thanks
Old Aug 9, 2014 | 10:06 PM
Restlesswildman's Avatar
Restlesswildman
The newer 6.0L have their weaknesses! EGR cooler, HPOP, stand pipes and dummy plugs come to mind. They still need to have the head studs put in them to keep them from popping a head gasket if you are going to be aggressive with it.
Old Aug 9, 2014 | 10:10 PM
lorts's Avatar
lorts
so there is no real benefit of having a newer 6L?
Old Aug 9, 2014 | 11:04 PM
9228.bobcat's Avatar
9228.bobcat
The newer ones have better hpop but would need to update dummy plugs, standpipes and stc fitting. It's not hard to put the newer motor in your 04. Does your 04 have the icp on the passenger valve cover?
Old Aug 9, 2014 | 11:11 PM
78fordman's Avatar
78fordman
Not really a big deal. As stated above may need to relocate icp wiring if you currently have an early 04.
Old Aug 10, 2014 | 08:20 AM
cheezit's Avatar
cheezit
Drop in 06 motor with 06 harness,
Old Aug 10, 2014 | 08:21 AM
lorts's Avatar
lorts
Yes the ICP is on the valve cover, what about the ecu or ficm are they interchangeable? Is it worth it going this rout? I thought the head bolts were stronger in the newer engines?
Old Aug 10, 2014 | 08:33 AM
9228.bobcat
Head bolts are the same. Use your ecm and ficm will be fine
Old Aug 10, 2014 | 08:37 AM
vloney's Avatar
vloney
You'll have to use the EBP sensor and tube from the 04 engine. Remember, when changing injectors, the 04 and 06 injectors are different (different part numbers).
Old Aug 10, 2014 | 08:50 AM
lorts's Avatar
lorts
The engine I'm looking at is complete with turbo it has 159kms on it from a wrecking yard for $3000cdn. Sounds like I should be fine installing this, I was going to install arp head bolts just to be safe and not sure to get egr delete or a egr from bulletproof. Thanks for all your answers.
Atom1234
Mar 18, 2016 10:49 AM
lupuseven
Jan 18, 2015 10:37 PM
Mattb60
Sep 22, 2014 04:57 PM
mfp4073
1983 - 2012 Ranger & B-Series
Mar 3, 2014 12:26 AM
280norris
Dec 27, 2012 05:59 PM
