Leveling Kit
Old Aug 9, 2014 | 10:22 AM
rdbesq's Avatar
rdbesq
Leveling Kit
I have a 2000 F250 diesel that I would like to update a bit. The local tire center suggested a leveling kit so that I could install slightly larger tires/wheels. What should I know about this? What should a kit installed cost? Are there different styles of kits? One brand better than the other? If you happen to live in Phoenix, do you have a recommended installer/sales place?
Old Aug 9, 2014 | 03:30 PM
BigAlsPSD's Avatar
BigAlsPSD
There are entirely new spring sets with built in arch, there are mini leaf packs, which are just short leafs to stack on the original spring set, and there are also longer shackles.
I went mini leaf, 2.7" of short springs, this allows for me to clear 35's. I bought them through sanderson welding for around $75 IIRC.
Old Aug 9, 2014 | 04:06 PM
SARDiverDan's Avatar
SARDiverDan
You might find answers for your questions here:
Leveling Kits, Truck Leveling Kits, & Suspension Leveling Kits from 4 Wheel Parts
Old Aug 11, 2014 | 07:05 AM
sowaxeman's Avatar
sowaxeman
My truck has a 2" leveling shackle kit. It has 285/75's on it and looks really good stand alone. However with the car hauler hitched up and the 'Stang inside, as you can guess it sits lower in the back than in front....the opposite of the problem the leveling kit was installed for. So if you are towing a lot keep that in mind.
Old Aug 11, 2014 | 12:10 PM
bdpotts's Avatar
bdpotts
i went with a 2.5" kit. leveled her right out. ran 315/75/16 with rub then installed airbags and installed new 285/75/16's with no rub. but with the airbags, the rear-end sits a bit higher again.
leveling kits are nice. i recommend!
Old Aug 12, 2014 | 06:06 PM
rdbesq's Avatar
rdbesq
How does that work? Can you do it yourself? Is there a good solution to leveling for $300 or less?
Old Aug 12, 2014 | 06:07 PM
rdbesq's Avatar
rdbesq
I just got a quote for $1100. Ouch!
Old Aug 13, 2014 | 09:18 AM
glockholiday's Avatar
glockholiday
Talk to the guys at Valley Spring Service they can do what ever you want. They build some of their owns parts and can do it on the cheap.
They lifted my 05' Excursion 4 inches, re-arced the front and rear springs with an add-a-leaf in the rear. Can't remember how much but it was definitely less than $1000 for all 4 corners parts and labor. For just your front it should be pretty cheap.
The front did ride a little stiffer though but I was ok with that.
2542 E Jefferson St, Phoenix, AZ 85034
(602) 275-0445
Old Aug 13, 2014 | 09:40 AM
F250_'s Avatar
F250_
I've been down this road. Some things to consider when leveling just the front end are as follows:
1. Pay careful attention to what happens to your front shocks. If you only raise the height of the front and the upper end of the shock is the only part which moves (like on a 2wd), then you have taken your shocks outside their normal travel range and can experience a degraded ride quality as well as potential shock damage from pushing them to their limits of motion.
2. You may need to shim your center carrier bearing to compensate for the slight change in geometry with the elevated front end. Some people have debated me on this, but I saw it clearly happen when I used a 2" leveling kit on the front of my 2wd F250.
3. Make sure to get your alignment checked thoroughly and adjusted after installing the kit.
4. You will see a slight decrease in fuel economy when you raise the front end.
Old Aug 13, 2014 | 09:41 AM
David7.3's Avatar
David7.3
Front leveling springs are acouple hundred bucks tops, I brought brand new procomp 6" springs, front and rear for $500. then I went with the adjustable trac arm, dropped pitman arm, and a set of rancho's all from J.C. Whitney. Free shipping plus a 20% discount, got my whole lift done for 8 and change. Now im running 35 toyo at's on procomps 16X10 rims. No rubbing any where, I made my own drop brackets for the bump stops. I also left the 350 4" blocks and the overload leaf in the rear, and the front had a drop shackle kit in it from the previous owner that I left in, It's like im running almost 9 inches of lift and have no worries about tire rub, when these wear out im going to 38"s.
fordka
Apr 20, 2013 10:27 PM
BigPigDaddy
Apr 15, 2010 07:24 AM
bschmitt
May 6, 2009 05:38 PM
THEDON117
Oct 31, 2008 07:13 PM
shenders99
Oct 20, 2006 09:58 PM
