Sponsored by: Real Truck
Turning Radius - 2015 F350 4x4
Old Aug 9, 2014 | 08:51 AM
Big-Foot's Avatar
Big-Foot
Arrow Turning Radius - 2015 F350 4x4
I have read other threads about wide track options on the F350 and F450 and wished I had known about it to order it on mine.
BUT
I just picked up my truck last night and drove it for the first time.
I don't know what the turning radius is on this truck (F350 CC DRW 4x4), but it will turn far FAR sharper than my 99 SD Supercab 4x4 would ever think of turning.
I did not even get the wheels turned tight against the lock and kept thinking "My God, the front U-Joints have got to be just about to bind point and can't believe that the front end isn't thumping and binding!!!"
So with that - does anyone have the turning radius info for the wide track vs. stock?
Good stuff Ford!!!!
Old Aug 9, 2014 | 08:59 AM
senix's Avatar
senix
coils vs leaf springs is one of the biggest helpful items.
Old Aug 9, 2014 | 11:01 AM
porthole's Avatar
porthole
Good stuff Ford!!!!
I drove one a week or so ago. In the same parking lot, my F+350 DRW versus a 2015 F-350 DRW with the wide track.
I had to do K-turns to move my truck around the lot. The 2015 - no K-turning required. Don't know what the degree difference is, but it is there.
Of course, you would not want to put it in 4WD low and do lock to lock turns on dry pavement (unless you did my hub disconnect mod)
Old Aug 9, 2014 | 05:59 PM
Modularation's Avatar
Modularation
Larger axle u-joints help turning radius also. Was the wide track option dropped on the F350 after 2010?
Old Aug 10, 2014 | 09:38 PM
Big-Foot's Avatar
Big-Foot
I took a look under my truck with the steering up against the lock. It could probably turn even tighter yet if the U-Joints could take it.. I don't need to chance it though..
Old Aug 11, 2014 | 07:26 AM
Modularation
"I have read other threads about wide track options on the F350 and F450 and wished I had known about it to order it on mine."
Randy, Could you have ordered it on yours?
Old Aug 11, 2014 | 07:29 AM
msgtord's Avatar
msgtord
What does the wide track option give you?
Old Aug 11, 2014 | 07:44 AM
Big-Foot's Avatar
Big-Foot
I don't recall the name or price of the option, but I believe so.
I recall that it had a heavier front spring rate, flairs and of course a wider track.
I believe you also got the 4.30 gear ratio - or that it was required.. I did not need that deep of a gear set. 3.73's are more than deep enough gears for me.
Old Aug 11, 2014 | 06:50 PM
Modularation
It includes larger ball joints.
Old Aug 18, 2014 | 12:03 PM
Mystic_Cobra's Avatar
Mystic_Cobra
Guys-
I am researching this topic right now. Ford calls it the "High Capacity Trailer Tow Package". It upgrades the rear axle gears to 4.30 as mentioned above.
It replaces the Class 3 front axle with a Class 4 axle. It adds the wheel flares. It ups the trailer capacity from 23200 to 26700 and GCWR goes up by 4500 (in 2015). It has also been called Tow Boss in some years.
FIRST DRIVE: 2015 Ford Super Duty pickups pack powerful improvements over 2014 models | Equipment World | Construction Equipment, News and Information | Heavy Construction Equipment
I know the Tow Boss pkg has been available on other years but not every year. You can see the tow ratings and evidence of the Tow Boss pkg on the Towing Guide for each year but it doesn't tell you what parts got upgraded.
I think the turning circle went from about 55 ft to 50 ft with the wide track. If I could get the wide track front end with 3.73 gears, I think that would be the best.
ice cream guy
Feb 12, 2019 09:18 AM
OkieSweetness
Nov 30, 2018 07:54 AM
Captkservices
Sep 5, 2016 12:48 PM
Blueheart
Oct 16, 2010 12:37 PM
