Help ficm count down
Old Aug 9, 2014 | 05:24 AM
Iaff113's Avatar
Iaff113
Truck was driving fine. Got off an exit and it died with a check engine light and battery light. Ficm reads 0 would it just have gave out like that
Is their a fuse or a relay that runs it. If so where is it located I couldn't find anything. And had to leave it to get to work.
Old Aug 9, 2014 | 06:22 AM
mustang_309's Avatar
mustang_309
I would start with checking the fuses and relays in the engine compartment.
Old Aug 9, 2014 | 06:40 AM
Iaff113's Avatar
Iaff113
Ok. I couldn't find out which one it was for the ficm
Old Aug 9, 2014 | 07:12 AM
Rusty Axlerod's Avatar
Rusty Axlerod
FICM fuse is labeled IDM (injector Driver Module)
^^^----under hood fuse panel
^^^^----under dash fuse panel
Old Aug 9, 2014 | 07:17 AM
Iaff113's Avatar
Iaff113
Thanks for true pictures! I will let you know what I find when I check that
Old Aug 9, 2014 | 07:23 AM
Rusty Axlerod
You're welcome. Our Techs often mention to check fuse 22 under the dash also. (F2-22)
Old Aug 9, 2014 | 08:22 AM
Iaff113's Avatar
Iaff113
Ok so checked all fuses that I originally didn't check. Pulled them out put them back in. Turned the koeo ficm reading 48.5 truck fired right up. Drove it the the firehouse. And volts stayed at 48-49 the entire ride. What would cause a sudden loss of power like that
Old Aug 9, 2014 | 08:53 AM
cheezit's Avatar
cheezit
Check the fan clutch wiring
Old Aug 9, 2014 | 08:59 AM
Iaff113's Avatar
Iaff113
I'll have to find a picture of where it runs too. I'm still learning. Thanks.
Old Aug 9, 2014 | 09:11 AM
cheezit's Avatar
cheezit
It runs from the the to the connector on the shroud. You may need a little mirror
Old Aug 31, 2014 | 07:40 AM
Iaff113's Avatar
Iaff113
Checked harness and nothing. Truck did it again yesterday and I watched the ficm volts go from 48.5 down to zero. Volts just kept gettig lower an lower. Shut truck off turn koeo and it's back to 48 and fires right up
Old Aug 31, 2014 | 07:44 AM
9228.bobcat's Avatar
9228.bobcat
I would check and load test the batteries and alternator. Also check battery and alternator connections.
Old Aug 31, 2014 | 07:49 AM
Iaff113's Avatar
Iaff113
Ok the batts are a year old. I wonder if sears will test them since that's where I got them from
Old Aug 31, 2014 | 07:51 AM
9228.bobcat
They should. Make sure they load test them separately.
Old Aug 31, 2014 | 07:59 AM
cheezit's Avatar
cheezit
Ok so if the 12v supply is there at the ficm and the 48v is droping off odds are a bad dc/dc converter
