Help ficm count down
Old Aug 31, 2014 | 08:07 AM
9228.bobcat's Avatar
9228.bobcat
Originally Posted by cheezit
Ok so if the 12v supply is there at the ficm and the 48v is droping off odds are a bad dc/dc converter
Guess he needs to check that when it acts up. If it's there looks like ed should get a call.
Old Aug 31, 2014 | 08:13 AM
Iaff113's Avatar
Iaff113
So if the batteries and alt Test out good. Should I just send the ficm the edd?
Old Aug 31, 2014 | 09:57 AM
Mr.Nobody's Avatar
Mr.Nobody
That's what I would do. He will test it and make sure it's broken before he fixes it.
Old Aug 31, 2014 | 11:25 AM
cheezit's Avatar
cheezit
Theres 3 ficm pids, check all 3, 2 should read 12v the other 48. If batts are good at you have 12v as you should yes off to ed.
Old Aug 31, 2014 | 01:36 PM
Iaff113's Avatar
Iaff113
Ok batts are 12.5 koeo ficm is 48.5. Once started batts are 13.5 ficm 48.5 and ficm sync is 1.
racerdon
Apr 5, 2018 07:56 AM
Jolly Roger Joe
23
Mar 12, 2017 08:14 PM
duste
Nov 19, 2016 08:48 AM
rbtom
Jan 2, 2015 05:50 PM
garyh8
Aug 17, 2011 10:09 AM
