Australia Chapter Join Chapter , Leader: ChunderDownUnder
Steering
  #46
Old 08-18-2014, 08:02 PM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
Thanks for clearing that up , i might pull the inspection plug and take a gander.
  #47
Old 08-19-2014, 04:21 AM
Aussie BrianB's Avatar
Aussie BrianB
Aussie BrianB is offline
How do you tell the difference?
  #48
Old 08-19-2014, 04:35 AM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
Powdered rods have a bolt and forged rods have a bolt and nut, if you pull the inspection plug you will have to manually turn the motor over and check when the bottom of the rod comes near the inspection hole and if you see a nut you have forged rods, if you see a bolt head you have powered rods , the power that you have in you motor is okay for both type of rods to handle.
  #49
Old 08-19-2014, 07:17 AM
Aussie BrianB
Blue,
Thanks for the info.
I see from your sig you have an LPG injection system fitted.
Who did the job and do you recommend it?
I have been considering it for some time.
I was going to do it to my 80 series 1Hz landcruiser but never
got around to it.
  #50
Old 08-19-2014, 04:19 PM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
Hey Brian, the LPG was on the truck just before i brought it , It was fitted by a company call torquegas, they are in Caloundra QLD, the job is very neat the mixer is in the left top corner of the engine bay and the filler was put in behind the filler for diesel and the tank sits under the truck directly below the left rear door on the side if the chassis rail, a real neat job , I'm sure most places would do the conversion now.
The LPG was fitted for towing purposes only and does it's job well it's very noticeable when towing steep grades, here a link to there site.
I'll get some photos after if you like but when the frost melts.
Torquegas | Torquediesel gas | Petrol Conversions | Diesel Conversions| Sunshine Coast, Queensland | Australia
  #51
Old 08-19-2014, 11:17 PM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
Okay Brian, here are the photos of the LPG setup .
This is the mixer and the electronics to run it all, it's in the LHF of the engine bay looking at the motor.
This is where they fitted the LPG filler along side the diesel filler
They supply the ID tag and do the reg transfer.
The LPG tang is 30ltrs which lasts about two tanks of diesel, the gas is only injected in when the revs are over 2200 IIRC
  #52
Old 08-20-2014, 04:39 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
How does the gas get into the engine?
Is it just a simple feed into the inlet pipe pre-turbo?
  #53
Old 08-20-2014, 04:53 AM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
Yeah the inlet tube to the turbo has a regulating valve going into it , I've not long fitted the 38R and had to do the necessary adjustments to the valve and inlet tube.
Just pulled the steering box , there's not much to it, has a heap of movement in it now it's off with no weight on it.
Up-date soon
  #54
Old 08-20-2014, 05:16 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
Hi Blue, tried to PM you but you hadn't set up your profile to allow PM's yet.
I've read a bit on steering boxes on the US forum. Apparently the shafts in the box just sit in holes milled into the housing. There are no shaft bearings!
There is a re-man box available from the states, don't know if there is a core charge, but they re-man the box with shaft bearings & get a much better result.
This is the one I think:
2001-2004 Ford Super Duty Steering Gear
Bryan hasn't chimed in about his Rocket Trucks RHD box, but Brian's concern about the replacement panhard rod mounting to the diff was enough to scare me off going down the RHD box path.
  #55
Old 08-20-2014, 05:44 AM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
Yeah I'm a bit slack today i must get to it and activate my PM profile.
I have been talking to National Steering in Vic they rebuild boxes , you send them yours and they rebuild it with oversize bearings and repack it ,with the oversize bearings.
They fit the bearings and it lifts the whole worm drive into another position, they also redo the worm drive , as that's the part that wears out. found these guys through Pedders .
  #56
Old 08-20-2014, 06:46 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
Sending it to the US for an exchange, you're probably looking at 2 weeks & $800.
If you're confident the local guys know what they're doing they could be a good option. Did you quiz them on how many F250 units they've done? I know the F250's are pretty popular in rural Vic, so there's likely to be some local skills & experience there.
  #57
Old 08-20-2014, 11:06 PM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
Yeah they said they have done a hell of a lot over the years , a lot the ambulances where in the list, the fact that they use over size bearings is a good point , anyway I'll let everyone know in a week or so when i fit it all back up.
  #58
Old 08-21-2014, 04:42 AM
Aussie BrianB
Smile
Blue,
Thanks for that.
It looks like they do a good job.
Interesting to hear you find it benificial when towing as this
is the main reason I bought the 'effy.
There is a company here in S.A. called DieselGas who have
been in the business for years and I have seen their work
at caravan & 4wd shows.
Their system looks to be very well made and installed.
Have you heard anything about their systems?
mrturtell
1999 to 2016 Super Duty
09-22-2016 06:39 AM
bulldog389
06-25-2013 08:28 PM
F-150_XL
05-11-2005 07:17 PM
olfordsnstone
10-14-2004 01:39 AM
Quick Reply: Steering
