AOD TV Adjustment
Old Jul 11, 2003 | 07:10 PM
goembel's Avatar
goembel
Question AOD TV Adjustment
Well I have been building a 75 F-100. I swapped the I-Six for a 351W with a Holley 4bbl. It had a 3 on the tree and I really wanted to get away from the manual drive, especially since my daily driver is a standard drive, so i bought an AOD that had came out of a late '80's Mustang. Well I haven't got to drive it yet because i was having trouble adjusting the TV cable. I have been told there is a bracket that goes on the carb to help with the adjustment but have been unable to find one. Do I really need it or can I just adjust it without the bracket? Its the stock cable with the block type adjuster on the end. Another question, can I use the mustang flywheel or do I have to get a new one for the 351?
Thanks for any help!!
Old Jul 15, 2003 | 01:27 AM
Stokes's Avatar
Stokes
AOD TV Adjustment
you would not be able to use the mustange flywheel due to it beeing balnced to a different weight. heh alot of good my reply is though being so late.
Old Jul 21, 2003 | 05:48 PM
javi2001's Avatar
javi2001
AOD TV Adjustment
Basic Idea for AOD TV cable adjusting is: TV lever must rotated same degress that Carb T. body. I mean rotational ratio is 1:1
After that you can make some light ajustments to TV cable adjuster to get soft shifting.
Regards;
Old Jul 21, 2003 | 06:43 PM
Usta's Avatar
Usta
AOD TV Adjustment
AOD's CAN BE A MILE OFF ON TV CABLE ADJUSTMENT AND STILL KIND OF FEEL GOOD, BUT THE TRANS WON'T LAST. dON'T CHEAT ON THIS ONE. GET A GAUGE ON LINE AND AT AN IDLE YOU'LL USUALLY SEE ABOUT ZERO....AND AS SOON AS YOU START BREATHING ON THE GAS PEDAL YOU'LL SEE THE PRESSURE START TO RISE. tHE BOOK DOES IT A LITTLE DIFFERENT BUT YOU'LL BE SAFE OR IN THE BALL PARK AND THEN YOU CAN FUDGE IT A LITTLE
Old Jul 22, 2003 | 01:38 AM
Stokes's Avatar
Stokes
AOD TV Adjustment
yeah!!! it will run out alot faster!!!! my AOD lived through 2 blocks becasue i was too loose!! it didnt even feal like it was doing anything that wrong at first untill i just got it out of my neighbore hood, noticed somthn was not right so turned back around. by the time i made it to my driveway, i was getting no forward drive whatsoever! learn from my exsperience. it still leaves me hitting myself. how often do you make mistakes with your truck that costs you a 1000$+?
Old Jul 22, 2003 | 05:57 PM
javi2001's Avatar
javi2001
AOD TV Adjustment
Yea, sorry guys I forgot recomend start using a high presure setting and then going down until get good shift. I there is a presure gauge from 0 to 30 psi, then do this:
1° Install pressure gauge at TV pressure port. Engine off.
2° Start engine, apply service brake, put AOD in Neutral pos.
(Be sure AC is off, engine is at normal Temp, DON'T PRESS GAS PEDALL WHILE GAUGE IS INSTALLED OR WILL BE BLOW OUT)
3° Adjust TV cable until gauge reads 0.5 to 1.5 psi at idle.
4° If AOD is used on trucks I recomend set it to 2 to 4 psi TV pressure. This will get cluch packs extended life loosing a bit confort.
5° Turn off engine, remove pressure gauge.
6° Be sure carb can get WOT pos. (Engine off)
LARIAT 85
'80-'86 HOWTO's
34
Jun 6, 2026 11:08 PM
Flat Ernie
19
Jan 22, 2015 06:57 PM
cwlightning03
1978 - 1996 Big Bronco
Mar 11, 2009 12:19 PM
Lightning4me
Jul 20, 2004 04:23 PM
