8.8" questions
Old Jul 11, 2003 | 05:32 PM
crash104936221's Avatar
crash104936221
8.8" questions
hey im wondering what the 8.8" axle will withstand power wise in the open diff and spooled with 3.55's ?
thanks
Crash
Old Jul 11, 2003 | 09:31 PM
MustangGT221's Avatar
MustangGT221
8.8" questions
Atleast 500 horsepower, but I suggest getting a new diff cover with the studs that put preload on the bearing caps. The stock diff cover is too weak. You can also get C-clip eliminators which arnt a bad idea. It's a pretty strong axle.
Old Jul 11, 2003 | 10:56 PM
77'F-150Mudder's Avatar
77'F-150Mudder
8.8" questions
Yea the 8.8 is almost as strong as a 9". It's an excellent light duty diff once you eliminate the c-clips.
Old Jul 12, 2003 | 05:16 PM
MustangGT221
8.8" questions
It's kind of hard to compair it to a 9", a lot of people argue back and forth. In my opinion they both have their pros/cons and are equal.
Old Jul 13, 2003 | 11:56 AM
BBBTruck's Avatar
BBBTruck
8.8" questions
seems ive stumbled across a great thread here, just what i was looking for...
yes i find the 8.8 is a strong axel, being my friend overloaded his 150 until the front end came off the ground and it only let go of a tube 6 months down the road after heavy off road and burnout abuse. I speculate the 8.8 replaced the 9 in production because it is cheaper to manufacture that design over a removable carrier/banjo housing. I am aware to the 9" excellent strengths and some of its weaknesses. My question lies in weight and efficiency:
A) what are the weight differences between the two?
B) Which one has less horsepower loss from the pinion to the wheels?
One cheap and dirty test for this would be the 80s f150 with a rear in good condition (Came with either axel depending on year) Place it on a dyno, check results. Swap in other axel making sure it has the same differential, gears and wheel size. Run again and examine results. Granted in higher horsepower applications friction differences can be a factor, but im sure this will show something. Anyone ever try something like this?
oh and dont forget a few other factors while testing: remove rear brakes, to ensure there is no dragging, also check the weight of the drums(possibly remove) and axel shafts to be somewhat equal for both.
Old Jul 13, 2003 | 05:36 PM
MustangGT221
8.8" questions
I don't think you'd find enough of a difference to make it a factor.
Old Jul 14, 2003 | 07:31 PM
77'F-150Mudder
8.8" questions
Agreed... C-clip issues aside you won't find an appreciable difference.
cowdog86
Mar 8, 2017 10:43 PM
Pocketlint
Jan 27, 2017 07:34 PM
puddintank
Jan 9, 2017 07:06 AM
reggiedunlop
1983 - 2012 Ranger & B-Series
Dec 22, 2016 09:19 PM
DallasSuperCrew
May 13, 2016 09:17 PM
