Anyone with 98-2003 e250/e350
Old Aug 6, 2014 | 03:36 AM
glovemeister's Avatar
glovemeister
Looking for pics of your power steering setup reservoir location, and number of ribs on pulley. Also do you have hydroboost or vac boost brakes?
Old Aug 6, 2014 | 05:43 AM
JWA's Avatar
JWA
What are you trying to accomplish? I have both a '00 & '03 E250 with 5.4 motor and vacuum-assist brakes.
Old Aug 7, 2014 | 12:26 AM
glovemeister
Looking to see how your power steering pump mounts to your engine, and also how many ribs your pulley has.
Old Aug 7, 2014 | 06:28 AM
JWA's Avatar
JWA
Here's something snapped just moments ago---not sure if you need more. If so let me know exactly what so I can do better.
HTH
Old Aug 8, 2014 | 01:59 AM
glovemeister
Very good appreciate the pics! Any chance you know or can tell if you have a separate cast aluminum bracket that your PS pump mounts to, or if it mounts into the side of the block?
Old Aug 8, 2014 | 05:57 AM
JWA's Avatar
JWA
I'll have to check that, might even be able to slide my camera and slightly shorter lens underneath too.
If that's possible I can get better images from under or below that whole system.
Gimme a few hours---work calls for now.
Old Aug 10, 2014 | 11:34 PM
OSHS's Avatar
OSHS
All the accessories on the mod motors bolt directly to the block. On the trucks, the power steering pump is down on the DS side. A/C compressor down on the PS side. Alternator in the middle of the V. The water pump is bolted to the block in the middle. There are different water pumps, depending on the motor (4.6/5.4/6.8) and also depending on the heads (2V, 3V, 4V). There are also different timing covers that, just like the water pumps, vary depending on displacement AND application.
-Remi
01 E-350 15-Passenger 20valve
99 ExpyEB 4x4 32valve
firstrider
May 12, 2018 09:16 PM
thepitshop
Jan 1, 2018 09:44 AM
lovethosefords
Mar 19, 2015 07:44 PM
AZGUY
May 28, 2009 01:59 AM
highboy 74
Offroad & 4x4
18
Apr 17, 2005 02:23 AM
