Sponsored by: Real Truck
Front end work
Old Aug 5, 2014 | 10:13 PM
11xmiller's Avatar
11xmiller
Front end work
Hi all
I Started tearing into my front end and my truck is terrible. Just bought new hub assemblies, ball joints, u joints, struts, axle seals, tie rod ends, and rotors.
My question is what else should I replace while I have it torn apart
Thanks in advance
Scott
Old Aug 5, 2014 | 10:54 PM
99f350sd's Avatar
99f350sd
Hi and welcome.
Make sure both axle seals. Brake pads and maybe new calipers..if they are over 80k.
Old Aug 5, 2014 | 11:16 PM
AAubinoe's Avatar
AAubinoe
Originally Posted by 99f350sd
Hi and welcome.
really new calipers? Im doing the brakes on my truck as well and the calipers appear to be OEM. I only pulled them apart because the pads were low, and then I realized just how corroded the rotors were. It was braking fine, cleaned off the rubber piston boots and they still look good.
Id just consider a caliper to be a replace it when it starts to leak deal.
Old Aug 5, 2014 | 11:21 PM
02 Super Duty Guy's Avatar
02 Super Duty Guy
CHECK YOUR EXHAUST MANIFOLD BOLTS!!!!!!
99FORD EXPY.
Jul 30, 2012 11:37 AM
championbuilder
Feb 13, 2012 11:30 AM
pittbull72679
Feb 9, 2012 02:30 PM
Vankaye
Jul 23, 2007 10:03 AM
giuntoc
Apr 29, 2007 02:13 PM
