Sponsored by: Real Truck
Thoughts or suggestions....
Old Aug 5, 2014 | 12:50 AM
Redrkt's Avatar
Redrkt
I want to upgrade to an '08 tailgate with factory camera and a touchscreen head unit (BT and camera ready) for hooking up my bumper hitch trailers but also am thinking about mounting a camera up by the third brake light for hooking up gooseneck/5th wheel hitches and would like possibly to connect both to the touchscreen and be able to switch back and forth, or should I add a second monitor for the bed camera?
Old Aug 5, 2014 | 08:49 AM
zimm's Avatar
zimm
You'll need to see if the headunit takes two AV inputs. Then you can switch between the cameras. I would put the tailgate camera as the backup camera, then put the high mounted one as manual switchable.
Of you could find a RCA switch and put that somewhere, and switch between cameras with that.
I found this answer on another forum: Adding a 2nd backup camera - Diesel Forum - TheDieselStop.com
Old Jan 28, 2017 | 07:11 PM
acecase's Avatar
acecase
I know this is an older thread, but if you haven't done it, check what I did.
https://www.ford-trucks.com/forums/1...ew-mirror.html
MUSKRATT2
Jun 11, 2010 08:37 PM
wildboar
1978 - 1996 Big Bronco
Dec 7, 2004 09:42 PM
mds01
Apr 6, 2004 11:24 PM
scootin
Sep 7, 2003 08:47 PM
