Horsepower/Torque
I have put on a 40 series flowmaster and changed out the piping to a 2 1/2 stainless with a K&N filter.
I really didnt notice too much gain for lower torque, but I have a heluva lot of top-end. I have considered either changing the plugs and wires, adjusting the timing by 4 degrees, or having the EFI checked out. Before I go through all the hassle I want to see if anyone has some insight.
Also I was wondering if taking off the flowmaster, and putting on a cherrybomb glasspack would do anything to help with the performance and sound.
I have given thought to putting on clifford headers, K&N intake, Diablo chip, and going from a dual cat, to a single high flow converter. Does sound like a way to give My F150 a kick in the ***? Please give me some feed back. Thanks
Shawn
Here are some cheap tricks to get some power out of the six. I have done these and it cost me next to nothing as I did them myself.
Exhuast 2 1/2" with high flow muffler and Cat. good for about 20hp and 30 ftlbs Cost about $175CDN
K&N filter and airbox mod. The airbox is super restrictive open it up buy removing some of the plastic at the bottom of the airbox (along the lines of a K&N filter charger setup). good for 12 hp and 16 ftlbs. cost $45cdn
Electric fan. got a shrouded fan from a P6000 at the scrap yard made bracks for mounting installed temp sensor. very noticeable at high rpm. good for 10hp and 15ftlbs. cost $15cdn
Restrictor plate for the egr valve. blanking plate with two 1/16" holes. this will get rid of that nasty 1800 rpm hestitation. Cost of 2 new gaskets $5cdn.
I have a 94 F150 4x4 4.9l mazda 5spd, 3.08 gears, 33x12.50's, locker in rear. and I tow a travel trailer(3700lbs) on a regular basis. In 4th gear will maintian 55mph on all but the steapest hills then 3rd will do.
>better choice the a 302 for pulling apps.
Where did you get those numbers? The 4.9L 300 had 150hp and 260ft/lbs of torque.
How do you figure the 300 is better for towing? The factory towing specs for the 302 are MUCH higher than that of the 300 in F-150s. A 5-speed 300 with 3.08 gears is rated at just above 2000lbs. The same with a 302 is around 3500 lbs.
'93 F-150 loaded and modified!
Check my Gallery
I think he means the 300 will pull a load easier due to its torque curve, not the towing rating Ford gave it. I haven't pulled yet with my 302, but just from the feel of them, the 300 would be my choice.
[font color="green"]1995 F-150 Supercab XLT longbed 4x4 302 M5OD [/font]31x10.50's
[font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job
I do quite a bit of towing with two different F-150's both 302 automatics. I've done some towing with a '92 4x4 300 automatic. Yeah I DO agree the 300 has good power at low-rpms, but I'd take the 302 for everything else. The 351's way ahead of either.
Check my Gallery
The 302 is only 4ftlbs more than the 300 with alittle more than 700rpm for the 302 to reach it's peak torque than the 300. The 300 will pull a larger load than the 302 at lower speeds. When I tow my Case W4 loader (8600lbs including trailer) the best I can get is 80kph and my truck factory rating is 2800lbs. That is (as stated by brown 4x4) is what I meant.
And yes if I was a constant hualer I would go with a 351, but not as a daily driver.
The 302 has 15ft/lbs of torque more than the 300 and with only a 400rpm difference.
Have you ever seen the graphs for each of the motors?
The 300 has more torque at 1000rpm than either the 302 or 351, but from there the 351 takes over.
The 300's torque peak is at 2000rpm and the 302's is 2400rpm.
Agreed, the 300 will tow more at lower speeds. That is IF you keep it under 1500rpm.
Check my Gallery
The hp and torque figures given by RoadRash are similar to the hp and torque figures of the 300 for 1968 in the USA (back when gross figures were used instead of net). If that is for a 90s fuel injected engine and if being Canadian it has less emission equipment, then that must be a pretty powerful engine that, if rated by gross figures as done in the 60s, would be closer to 200 hp and 335 pound-feet. Ya-hooo--pedal to the metal! Have some fun!
INLINE SIX POWER!
300 Cubic Inches of Low RPM Truck Torque! And twin-I-beams too!
>available engines for F150 through F350. The interesting
>thing is that the base engine in the F250 is the 300 I6, but
>they didn't even offer the 302 in the F250. I assume this
>is because the 302 doesn't hold up as well to heavy duty
>service.
I'm positive Ford offered the 302 in F250's. In HS my boss bought a new std cab '86 4x4 F250 with a 302.
Jeff
The 302 was available in 3/4tons both LD and HD until about 1992 or so. Then it and the 300 were only available in the light duty F250. The 351 became std in the HD 3/4tons.
Check my Gallery
>Check my Gallery
Are you sure about the 302 in an F-250 HD? My 86, 93, and 95 literature all list the 300, 351, 460, and diesel available in HD, and 300, 302, 351 in LD's. You could only get the 300 in an F-250 HD 4x2 and the 351 was standard in 4x4's.
Check my Gallery
F100: 300, 302
F150: 300, 302, 351
F250: 300, 302, 351
F350: 300, 351, 400
Also, we must remember that the 300 (HD version) was used in F600s and school buses along with other big trucks. I suspect the F350 300 was likely an HD version (HD had forged alloy steel crank and other HD parts).
