Stalling at stop lights?
Old Aug 2, 2014 | 09:54 PM
USMC:302's Avatar
USMC:302
I've been [elbow] deep in my truck for the past couple of weeks trying to figure out why it keeps stalling, and not wanting to immediately restart, at stop lights, corners, etc. It's a '79 F100, 2wd with a 302W and a 4 bbl carb. I thought it was vapor lock, so I put thermal shielding on the fuel line by the block, but it's still happening. Could it just be that the carb needs to be tuned, or something more sinister? Any answers, conjecture, or just straight up swearing would be greatly appreciated.
Old Aug 2, 2014 | 10:12 PM
dlburch's Avatar
dlburch
need some more details. does it idle normally when you first start it (in park). Does the problem only happen with the tranny in drive (assuming auto)...is it worse when the brake is depressed?
Old Aug 2, 2014 | 10:28 PM
USMC:302's Avatar
USMC:302
It happens when I'm in any forward gear (c4 auto: D, 2, 1), usually when I'm in drive. It does happen when my foot is on the brake, but having my foot off the gas seems to have more to do with it than having my foot actually on the brake. In park it idles pretty high, and usually has a tough time firing up when I go to start it. If I'm driving down the road it works fine and pulls hard with no hiccups. To be clear, the ignition, starter, spark plugs, etc. are all in good working order.
Old Aug 2, 2014 | 10:38 PM
0ldman's Avatar
0ldman
Sounds like a vacuum leak. Check your hoses, carb, intake, etc for hissing sounds.
Old Aug 2, 2014 | 11:00 PM
co425's Avatar
co425
I'd check your float level. If your floats are wrong you'll starve and die upon a stop.
Old Aug 3, 2014 | 02:09 AM
montana_highboy's Avatar
montana_highboy
X2 on the float level.
When you brake, corner, etc., the fuel rushes towards the front of the float bowl, if the float is adjusted on the low side you'll starve the motor. Re-set float and all is golden.
Old Aug 3, 2014 | 09:27 AM
USMC:302's Avatar
USMC:302
Awesome, so on to the next rookie question: Would replacing the entire sending unit fix this problem as well? My feeling is that after 35 years it might be about time, and if I'm going through the trouble of getting into the fuel tank that I may as well. How hard would it be to get this taken care of?
EDIT: I think I may have misunderstood, are you talking about the float in the carb bowl?
Old Aug 3, 2014 | 10:25 AM
co425's Avatar
co425
Yes, floats in the carb.
Old Aug 3, 2014 | 12:44 PM
USMC:302's Avatar
USMC:302
Got it, I really appreciate the advice, time to go to town on the carb. Hopefully some of the Edelbrock carb horror stories I've heard aren't coming my way...
Old Aug 3, 2014 | 05:42 PM
co425's Avatar
co425
Hell, eddy's are the easiest carbs to work on in my opinion.
Old Aug 3, 2014 | 05:47 PM
montana_highboy
I never understood the bad rap, Eddy's are pretty simple and straight forward, certainly more so than Holley's anyway. Eddy carbs are basically "set it and forget it" I haven't touched my current Eddy in over ten years....no need to. Holley's are more fickle, a cloud rolls over and drops temps 20 degrees and you need to re-adjust the damn thing.
My one and only complaint with Eddy's is the small float bowl, it tends to evaporate the fuel more quickly due to its small size, and the fact that Eddy's draw their pump shot from the top of the bowl doesn't help matters any. It can make for difficult starts (excess cranking) after the truck sits for an extended period of time.
Old Aug 3, 2014 | 06:24 PM
USMC:302's Avatar
USMC:302
Glad to hear it, maybe I'll just keep a can of ether on me from now on. Time to get this thing dialed in, I'd ask for specific advice on setting the float and tuning the carb, but I'm sure there are threads already out there for me to peruse. However if anyone has a link to such a thread it would be appreciated.
Old Aug 3, 2014 | 06:40 PM
co425's Avatar
co425
If you go on edelbrock's web site the manuals for all their carbs are available for download. They are very simple to tune and rebuild. May want to think about a rebuild since it will be opened up for the float adjustment anyway. Also check out you tube. They may have a rebuild tutorial on there.
UnOmENe
Apr 14, 2019 07:27 PM
Sean Schrader
May 15, 2017 09:16 AM
vscrl
Jun 15, 2012 08:21 PM
HogHunter
1978 - 1996 Big Bronco
Jun 15, 2003 09:59 PM
airwulf
Jun 10, 2001 09:51 PM
