which transmission?
Old Aug 2, 2014 | 09:21 PM
hwebb45's Avatar
hwebb45
which transmission?
New here and just picked up a 77 f100 2wd swb according to vin it was originally 302 3 on the tree the guy I got it from said it was swapped to a 360 and 4 on the floor from a 72 car. no question about the motor but he said reverse is all the way to the right and up. I picked it up yesterday and haven't had time to get it running but I was wondering what transmission it is. It is the smallest as in shortest transmission I have ever seen. Thanks in advance
Old Aug 3, 2014 | 02:41 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
NP435 = aluminum top cover w/8 bolts
T-18 = cast iron top cover w/6 bolts Warranty Plate TRANS code: A = NP435 (N-1965 only) / F = Warner T-18 / P = F350 Warner T-19.
Warner shift lever retainer cap (8MTH-7220) threads on/off.
NP435 shift lever retainer cap (B8T-7220-D) has two notches, is retained to shift tower by two pins.
To remove this cap, it must be pressed down and held down while turning it to remove it.
People unaware use pliers or channel locks to remove it, which tears out one or both of the notches. Not pleasant! Now they aren't going anywhere.
Originally NP435: Reverse-down towards the seat while Warner T-18: Reverse-up towards the dash.
The reverse shift pattern was changed circa 1973, but I can't recall for which of these 4 speeds.
Note: There's another 4 speed: RUG SR-OD Single Rail 4 Speed Overdrive introduced in 1978 F100/150 300/302, TRANS code B
Old Aug 3, 2014 | 06:41 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
See if you can find a id number on it. Here is a link to the Ford car tranny's. Toploader ID Chart
Old Aug 3, 2014 | 07:34 AM
co425's Avatar
co425
Are you sure it's right and up?
The np435 and also I believe t-18 reverse is to the right and back.
Like so
13
24R
Old Aug 3, 2014 | 02:31 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
2wd , car tranny opens up possibilities.
C Stump
Mar 22, 2016 09:49 AM
NVFord81
Jan 20, 2016 08:07 PM
Andresito
Feb 20, 2015 02:32 PM
therrera1550
23
Dec 28, 2014 01:34 PM
BogTroll
May 10, 2014 08:54 AM
