View Poll Results: What is the 0-60 time for your 5.4l 2v 4wd expedition?
9 seconds
0%
10 seconds
0%
11 seconds
50.00%
12 seconds
0%
13 seconds
50.00%
Voters: 2. You may not vote on this poll
Sluggish Acceleration
Old Aug 2, 2014 | 04:35 PM
DriverDan's Avatar
DriverDan
Thumbs down Sluggish Acceleration
Hey guys, I'm new to this forum so first off I thought I would say hello! I have been a lurker for many years, but now that I bought a Ford truck, it is time a make an account! To start off with, I purchased a 2003 Eddie Bauer 4wd Expedition with the 5.4l. It has 150,000 miles and looks to be in pretty nice shape. It drives well, smooth acceleration and shifts, and so far the computer is noting around 13-13.5mpg for all city driving, which seems decent for a vehicle this size. I searched the web, and it seems the 0-60 for this vehicle should be right around 9.5-10 seconds. However, when I went to test it it took just shy of 13 seconds to reach 60! . I have no idea what might be causing this loss of power, as there are no codes. This seems like too big of a decrease to ignore. I tried cleaning the MAF, replaced the air filter, and cleaned the throttle body, but still clocked in at 12.8 seconds. Also, the tires are all filled to spec. My next move is to change the fuel filter. I'm considering doing the spark plugs, but could old spark plugs (changed 50,000 miles ago) really make that much of a difference? It just stumps me because the mpg's are still great, however there is a large lack of power, and the two wouldn't seem to go together. I'd appreciate any help you guys can give me!
Old Aug 2, 2014 | 08:57 PM
SilverSS's Avatar
SilverSS
I thought something was wrong with mine when I got it but it runs fine and my mpg is the same as what you're getting. They're just not that quick. What gears do you have? What size tires? Those will make a pretty big difference. I'll try and clock my 0-60 when I get a chance. I've got 3.73's and 285 70/17's.
Old Aug 2, 2014 | 09:52 PM
DriverDan's Avatar
DriverDan
For tires I have 265/70/17's and 3.73's. If you do go out and test it, let me know! I'd like to think I'm not alone
Old Aug 3, 2014 | 12:50 AM
alloro's Avatar
alloro
9.5-10 seconds when new or when it has 160K on it?
What octane gas was used?
Old Aug 3, 2014 | 08:57 AM
DriverDan's Avatar
DriverDan
New, however I've seen videos of them with just around the same mileage as me getting just a hair above 10 seconds. And I'm using 87 octane
Old Aug 3, 2014 | 09:59 AM
alloro's Avatar
alloro
For starters you could try running 93 octane and then retesting your speed. This will keep the timing a bit more advanced, but also keep it down to a 1/4 tank when testing, the extra weight of a full tank will slow you down. Another variable to ponder is your elevation above sea level. The higher you are the thinner the air and the less HP the engine outputs.
Old Aug 3, 2014 | 06:56 PM
DriverDan's Avatar
DriverDan
Ahh I see, I will definitely give that a try. Thank you for your help!
Old Aug 4, 2014 | 03:32 AM
alloro's Avatar
alloro
As you can see, there are many variables that can and will affect performance. The only way to rate your truck against others is to make sure the conditions are as similar as possible. Your 13 seconds might be just right for both the area you're in and the age of your truck.
Old Aug 4, 2014 | 01:01 PM
KeystoneHomeOK's Avatar
KeystoneHomeOK
I tried to time mine and it laughed at me.....I'll give it shot with my OBD reader plugged in and the timer set up on my iPad. We'll see what happens.....
Old Aug 4, 2014 | 06:01 PM
DriverDan's Avatar
DriverDan
That's true...for now I'm just going to change the spark plugs, and be happy I'm still getting good mileage.
DriverDan's Avatar
DriverDan
Let me know! I'm curious to see what others are at
bbdano
Jan 28, 2011 04:39 PM
psu1xj
3.8 & 4.2L V6
Sep 27, 2006 08:08 PM
frdtruc1
New Hampshire Chapter
Feb 21, 2006 08:27 AM
JC947386
1997 - 2003 F150
Jan 18, 2006 11:39 PM
Ken00
1983 - 2012 Ranger & B-Series
Feb 13, 2002 02:52 PM
