76 F100 Ignition issues
Old Aug 1, 2014 | 09:53 AM
corkel's Avatar
corkel
Hey folks. I have a 1976 Ford F100 with a 302 and my problem is sometimes when my engine is running and I try to cut it off, it continues to run and the only way to stop it is to jerk the coil wire off. This is an intermittent problem. Happens about every 6 or 7 times I drive it. I have replaced the ignition switch and still have the same problem. Pretty sure it is some type wiring or ground issue, just need someplace to start. Thanks in advance.
Old Aug 1, 2014 | 10:14 AM
fmc400's Avatar
fmc400
MSEE
The next time it happens, instead of pulling the power to the coil, remove the BROWN wire going to the small 'I' terminal of the starter solenoid. If that kills the engine, the starter solenoid is bad and must be replaced.
Old Aug 1, 2014 | 01:27 PM
corkel's Avatar
corkel
Thanks fmc400, I will give that a try.
SamBozo
Mar 6, 2022 09:44 AM
corkel
Electrical Systems/Wiring
Aug 1, 2014 02:19 PM
72CC428
Dec 27, 2012 06:51 PM
lowtrkn2k
Oct 3, 2012 05:01 PM
koryz
Aug 15, 2012 08:58 PM
