transmission not working
Old Jul 31, 2014 | 05:04 PM
tito8824's Avatar
tito8824
Just changed the filter and transmission fluid on my expedition got about 226xxx miles transmission was slipping prior to the change now that I changed the filter and about 5 qts of dextron v it's not going into gear at all it will only go into reverse!! Help plz any input is great
Old Jul 31, 2014 | 06:16 PM
SoCalAngler's Avatar
SoCalAngler
Are you sure it only take 5qts? That seems like too little. Did you check to see what it is supposed to hold? Also, when warm and in Park, did you check dipstick for proper level? Some check dipstick level while trans is in Neutral, but if doing so, you need to be sure truck's wheels are blocked, parking brake set, and BE CAREFUL!!!
Old Jul 31, 2014 | 07:41 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
5 quarts isn't enough. And Dexron V is the wrong fluid and might damage the transmission.
I recommend getting the Dexron V out of there and using MERCON V. That is NOT the same as Dexron V.
SoCalAngler
Jul 1, 2018 08:41 AM
hgufrin
15
Oct 24, 2017 02:39 PM
timmygyu
Sep 7, 2012 07:52 PM
67Ray
Escape & Escape Hybrid
Feb 25, 2011 11:20 AM
jgrm2
1997 - 2003 F150
Jul 22, 2004 08:52 PM
