Angle for loading ramp
Old Jul 29, 2014 | 01:10 PM
E Bjornstad's Avatar
E Bjornstad
Former Vendor
I just bought a 4' x 8' trailer from Tractor Supply, partly to be able to haul my lawn tractor. I'm planning to build a little loading ramp. So this is a good chance to dust off my high school trig. What is the ideal angle to stick below for loading? Obviously if I want to hit a given angle, that will influence how long the ramp needs to be. Is it 20%?
Old Jul 29, 2014 | 01:40 PM
BossGasser's Avatar
BossGasser
Getting over the break from the ramp to the trailer floor is the math part.
A guy I worked for couldn't haul the mower he built the trailer for!!!
Raise the deck and measure height from ground then the wheelbase.
That will give you a starting triangle.
Old Jul 29, 2014 | 07:55 PM
senix's Avatar
senix
Break over is the deal killer. I load mine in the bed of the truck with some motorcycle ramps and it clears.
If that gives you any ideas
Old Jul 30, 2014 | 07:07 AM
wingedone's Avatar
wingedone
Then use this ramp calculator to determine minimum length.
Ramp Calculator
Old Jul 30, 2014 | 08:54 AM
thomabb's Avatar
thomabb
If you want to try to remember your high school trig and you need another project, then go for it.
If you want the professionals to take care of it for you,
Folding Lawn Mower Ramps
I had a couple 2X8s with ramp tips mounted on one end to get my mower/snow blower in and out of the truck. Had to stay below 8' so they would fit in the bed. Since I now load the VTX, I have upgraded to an aluminum folding ramp system. They make them for all kinds of applications and are so much better than the home made solutions.
Just my $0.02...
Old Jul 30, 2014 | 09:07 AM
jdadamsjr's Avatar
jdadamsjr
break over is the key - like the way those folding ramps arc to 'level' out the load at the top, but the last line of their site is cautionary
Not recommended for golf carts, zero turn lawn mowers, heavy small wheeled vehicles, dollies, or wheelchairs.
so what Do they recommend it for and what does "heavy" mean to them ?
Old Jul 30, 2014 | 09:26 AM
thomabb's Avatar
thomabb
Anything that would be top heavy would need a longer ramp so it wouldn't tip back while going up.
Youtube is full of examples of other people's failures.
Old Jul 30, 2014 | 04:50 PM
BossGasser's Avatar
BossGasser
A ramp calculator!?! WOW!!
Every time I think something might be missing from the Web, it shows up.
Looneybin
Dec 27, 2021 10:25 AM
wntrwhte
Aug 27, 2018 06:54 PM
SCREW
All Things Towing
Dec 4, 2015 05:33 AM
jniolon
45
Sep 1, 2010 10:17 PM
Buckarcher
All Things Towing
Sep 18, 2004 08:52 AM
