Sponsored by: Real Truck
3.73 vs 4.10
Old Jul 11, 2003 | 05:35 AM
fountain31's Avatar
fountain31
Question 3.73 vs 4.10
I am new to this forum and this topic may have been covered before. However, I currently have an '02 F250 V10 CrewCab,SB, Lariat with 3.73 rear end. I am looking to purchase an F350 DRW and have found this choice to be very confusing. Its either a diesel with 4.10 rear end or V10's (very scarce) with a 3.73. I am planning on getting a fifth wheel in the spring plus I tow every weekend throughout the year. The question I have is; Since I use the truck back and forth to work as well as tow, what rear end should I get? Is the 4.10 much different on fuel?
Old Jul 11, 2003 | 06:35 AM
powerstroker250's Avatar
powerstroker250
3.73 vs 4.10
What kind of weight are you pulling around?
Old Jul 11, 2003 | 07:14 AM
fountain31's Avatar
fountain31
3.73 vs 4.10
I am currently pulling ~6,000 for my snowmobiles + gear, ~8,200 for my boat loaded with fuel and the fifth wheel s/b about 9,000lbs
Old Jul 11, 2003 | 07:36 AM
MrFeexit's Avatar
MrFeexit
3.73 vs 4.10
As an add on what do those numbers mean exactly?
Old Jul 11, 2003 | 11:31 AM
nafzimo's Avatar
nafzimo
3.73 vs 4.10
It is the ratio of rotation of driveshaft to rotation of wheel.
3.73 rotations of the driveshaft = 1 rotation of the wheel.
Old Jul 11, 2003 | 01:05 PM
MrFeexit's Avatar
MrFeexit
3.73 vs 4.10
so the higher the number the more tork at the wheel and the lower the number the faster your rear wheel would turn...so for towing you would lean towards the higher numbers right?
Old Jul 11, 2003 | 06:35 PM
mikelehmann's Avatar
mikelehmann
3.73 vs 4.10
right MrFeexit
Old Jul 12, 2003 | 07:02 AM
powerstroker250
3.73 vs 4.10
You should be ok with 3.73's with that weight.
fireball318
Modular V10 (6.8l)
Jun 4, 2013 05:10 PM
damone
Modular V10 (6.8l)
17
Jun 6, 2006 01:01 AM
Hedgehog1
Nov 28, 2004 08:50 AM
bigbird1
Aug 5, 2003 10:13 PM
stover007
Modular V8 (4.6L, 5.4L)
Apr 17, 2003 07:57 PM
