Fitting 35s
Old Jul 28, 2014 | 09:25 PM
fordka's Avatar
fordka
Fitting 35s
Whats the min lift needed to fit 35-12.5-15 tires on a 88 bronco. Its got the gearing for it 4 10 rpms are still high with 31s. Its factory height. Dunno who would order a bronco new with 4 10 in the first place but whatever i guess.
Old Jul 28, 2014 | 09:27 PM
JKNW's Avatar
JKNW
Depends, how opposed are you to cutting fenders? They can fit with no lift if you want them to, I've done 35's no lift on much smaller trucks but you do have to trim and hammer to get there.
Old Jul 28, 2014 | 09:29 PM
fordka's Avatar
fordka
Ya i dont want to do that my fenders are just about rust free for a ny truck so i wouldnt be able to let myself do it.
Old Jul 28, 2014 | 09:57 PM
Evan_P's Avatar
Evan_P
6" minimum.
Old Jul 28, 2014 | 10:00 PM
fordka's Avatar
fordka
Yikess i personally hate lifting these.
Old Jul 28, 2014 | 11:12 PM
Crewcabber's Avatar
Crewcabber
Do an SAS and throw some 35s on it and be done.
Old Jul 28, 2014 | 11:39 PM
LeoJr's Avatar
LeoJr
Bronco, F1/2/350 sheet metal is all tha same? Here is 35" tire on a F250 that has sagged to within 3/4" of the rubber bump stops. The tire actually measures 33". The bumper is easily the limiting factor. I don't know how that transfers to your axle and its relation to your bump stop, maybe someone here knows?
And here is the exact same tire (different style but same dimension rim) with about 3" of lift (swapped D50 TTB to a solid D60 and F350 springs) but the biggest contributor to clearance is the aftermarket bumper.
Old Jul 28, 2014 | 11:43 PM
Evan_P's Avatar
Evan_P
The sheet metal is, but the stock ride height is not. You can fit larger size tires on a stock F250/F350 than you can on a stock F150 or Bronco.
Old Jul 28, 2014 | 11:52 PM
LeoJr's Avatar
LeoJr
Oh I don't question the ride height difference at all, the axle tubes are different diameters, coil spring perches versus leaf springs, etc. But there has to be a measurement that can be transferred between them like the centerline of the axles to the frame... or similar. I think too many people assume that a F350 can fit more tire than a Bronco...its the same sheet metal, different axles and springs.
Old Jul 29, 2014 | 12:18 AM
Evan_P's Avatar
Evan_P
Its the axles and springs that make the difference.
Here is what my truck looked like on 35's with a 4" lift.
The tires would rub the bumper valance any time I turned on flat ground. If I hit a bump turning they would hit the metal on the bumper. They also rubbed the radius arms A LOT. Overall horrendous combination.
Old Jul 29, 2014 | 05:08 PM
fordka's Avatar
fordka
Probly not gonna get the tires then. I dont like driving a bronco the begin with. Motors junk i think and i need to get a truck. So this is going down the road shortly.
Old Jul 29, 2014 | 07:56 PM
Diesel_Brad's Avatar
Diesel_Brad
6" lift and 35s
Old Jul 29, 2014 | 09:30 PM
fordka's Avatar
fordka
Originally Posted by Diesel_Brad
6" lift and 35s
I like that. Wish mine came lifted
Old Jul 30, 2014 | 04:37 AM
Diesel_Brad
And it also has 4.56 gears to actually power the truck
Old Jul 30, 2014 | 12:59 PM
fordka's Avatar
fordka
Mine has 4 10 which i think is plenty. But i wont be doing anything to it now the trans just took a ****.
mjl351w
Offroad & 4x4
Nov 26, 2003 09:17 PM
90Bronc
1978 - 1996 Big Bronco
Sep 5, 2002 04:45 PM
restorit
Dec 15, 2001 10:56 PM
sean
Dec 14, 2001 07:58 AM
kd206
Offroad & 4x4
Mar 13, 2001 07:22 AM
