speedo difference
Old Jul 27, 2014 | 01:32 PM
hillcountryflt's Avatar
hillcountryflt
speedo difference
Been noticing that I seem to be running a little fast compared to other traffic around town.
So I took the truck on the Interstate to compare odometer to mile markers.
Basically for each real mile of travel, my odometer is reporting about .85 or close.
So is a close approximation essentially speed plus 15 percent? If that is the case my MPGs shows to be about 11.
Of course would like to correct it, but not a pressing matter. most of the driving is below 30-45 mph around town, so easily adjusted for. I thinking the correction is changing out the speedo gear in the tranny.
Old Jul 27, 2014 | 02:36 PM
Gembone's Avatar
Gembone
the gear on the end of the cable transmission side comes in 5 different versions to adjust the speedometer. I believe they are all still available from Ford. They will have more or less teeth. pull what you have to see witch way you need to go.
Old Jul 27, 2014 | 05:23 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Gembone
the nylon DRIVEN gear on the end of the cable transmission side comes in 6 different versions (16 thru 21 teeth) to adjust the speedometer. They are all still available from Ford. They will have more or less teeth. pull what you have to see which way you need to go.
Approx. 5-7 MPH difference for each of these gears. If the truck has P-Metric radials, the speedo will never read correctly.
Old Jul 28, 2014 | 02:40 PM
JEFFFAFA's Avatar
JEFFFAFA
2X Bill. The nylon gears are color coded. Different gears for Manual trans or Automatic. Less teeth than what you have now will speed up the speedometer. A present tooth count and a pic of your old one will make it the easiest on either Bill or myself to give you the part number for the gear you need.
Old Jul 29, 2014 | 11:17 AM
hillcountryflt
Next time I am in a position to pull the speedometer gear, I will. I am guessing it is pretty simple process on my tranny.
I will try this weekend, unless it is something I can do without lifting the truck (don't have my jacks and jack stands at my house) in my driveway.
Then I might try to get to it earlier - while I am cussing at trying to get some semblance of a functioning fuel gauge.
Old Jul 29, 2014 | 12:38 PM
JEFFFAFA's Avatar
JEFFFAFA
Oh yeah. Crawl under there on a Kreeper. Where the speedo cable goes in the L/R of the tranny is what you want to remove. The speedo gear will be on the end of it.
Old Aug 10, 2014 | 06:06 PM
hillcountryflt
Finally pulled the speedo gear - t18 D1.
one of the easier things to replace.
Old Aug 11, 2014 | 02:02 PM
JEFFFAFA's Avatar
JEFFFAFA
Yellow gear is 18 tooth manual trans. 18 X .85 = 15.3. Lowest number teeth gear Ford makes (still) is 16. 16 tooth M/T gear is part number CODZ17271A. color coded:wine.
Old Aug 11, 2014 | 03:53 PM
hillcountryflt
Thanks.
Ford house will have me one this week. Jeez NOSparts had it for $45 plus shipping. Good grief. About $5 everywhere else including my dealership.
Old Aug 22, 2014 | 11:01 AM
hillcountryflt
Finally installed the replacement speedometer gear.
Using the mile markers on the interstate I was showing right at .95 to 1 mile. Pretty darn close.
Thanks for the help here.
Old Aug 22, 2014 | 03:50 PM
JEFFFAFA's Avatar
JEFFFAFA
Ya gotta love it when a plan comes together..........
Old Aug 22, 2014 | 08:47 PM
Uni Moe's Avatar
Uni Moe
If you have a smart phone you can get a gps app to tell your speed. I used AwesomeHUD. You can actually use it in heads up display mode.
hest_c
Jun 27, 2016 10:43 AM
Erik Jaeke
Oct 1, 2015 04:06 PM
Adam Woolridge
Sep 16, 2015 04:50 PM
78ford351m
Nov 12, 2008 12:18 AM
