Computer Chips & Tuners
Best performance chip? your opinion.....
Old 05-08-2003, 04:54 PM
1997ford5.0L's Avatar
1997ford5.0L
1997ford5.0L is offline
I'm currently in the market to buy a new computer chip. I do have a couple questions. First I have a 1997 Ford Explorer, AWD, 5.0L V8, 4 door. I also have a Gibson exhaust, K&N air filter (soon to be FIPK), 180 degree thermostat, and use 89-92 octane fuel, and occasionally 87.
Ok:
1.) Do all the chips use the same port, or can I get two seperete ports an this have 2 tuner chips? (I'm very new to this.)
2.) What chip do you recommend best? Why?
3.) What chip will give me the best performance and highest horsepower and torque increase?
4.)What are the difference chip manufacturers? I've onlyseen one or two for a 5.0L Ford 1997 SUV.
5.) Can you use the same year chip for a different car? Like if I were to buy a 1997 5.0L Mustang chip, could I us it on my Explorer?
6.) How well do they increase performance. I mean, with more horsepower and torque, plus new shift points and shift firmess,does it make a big difference?
7.) Anything else you want to recommend?
Thansk guys, I love this forum already!
Old 05-09-2003, 08:58 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
All chips use the same port. There is only one port. A "tuner" uses a different port (OBDII) but a tuner cannot be used with a chip.
The Diablo Delta 2 stage chip. The performance mode requires premium but the switch allows you to switch to the stock (87 octane) tune.
Diablo, on average, has better increases than Superchips.
The different is the performance and the level of support, plus the hardware. Superchips does not have 4 bank chips (you can't work around non-start issues) and since their Microtuners came out their chip support has declined. Diablo has been and continues to be very supportive of their chip market.
You would need to have the chip reprogrammed.
Check out our chip frequently asked questions:
http://www.motorhaven.com/Web_store/Html/chipfaq.html
Old 05-12-2003, 03:17 PM
1997ford5.0L
Anyone else?
Another question: How would I change between the stanges on a Diablo (what I'm going to buy) Delta 2. I plan on using both 87 and 93 octane. Is it something hard or easy?
Old 05-12-2003, 06:07 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
The 2 stage chip cannot switch on the fly. You would need to turn off the ignition to switch between stock and 93. Only the 3 stage chip allows switch on the fly. The chip comes with a 5 foot cable with a switch on the end.
Old 05-12-2003, 07:37 PM
1997ford5.0L
Right thats not that bad...but, I turn off the ignition, then what? Remove the chip?
Old 05-12-2003, 07:45 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Turn off the ignition, flip the switch. Turn on the ignition.
Old 05-12-2003, 07:49 PM
1997ford5.0L
So they all come with a switch. Cool. Thanks!
Old 05-13-2003, 02:45 PM
1997ford5.0L
One more question.
Does it also alter shifting with the overdrive off?
Old 05-14-2003, 09:34 PM
Rand's Avatar
Rand
Rand is offline
If you lock out overdrive.. you lock it out. This has no effect to the chip.
Old 05-16-2003, 05:21 PM
1997ford5.0L
Right, so you'd still have a faster shift?
And webmaster, I know where the computer box is......where is the number I need on the box? Is in out the outside below the harness? I see the wire harness that plugs into the box that holds the chip, is it on that box? There are like 4 seperate numbers.
Does F57F sound like the one?
I'm hopefully buying a chip from your storenext week, and want to make sure on the right number I'm getting.
Old 05-18-2003, 04:04 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Yes, you'd still have a faster shift.
Code is 3 letters followed by 1 number. For example: CGY1
Old 05-18-2003, 05:59 PM
1997ford5.0L
Ok, and whre can I find this number on the computer box. I don't see any with 3 letters and 1 number.
Old 05-18-2003, 06:40 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Here.
Old 05-18-2003, 06:49 PM
1997ford5.0L
Ok, cool. So, if I order tomorrow night, when should I expect it?
Old 05-18-2003, 07:16 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Anything that takes more than 3 days according to the UPS zone charts we send "UPS 3 Day Air" so its going to be 1-3 days depending on where you live.
Quick Reply: Best performance chip? your opinion.....
