Sponsored by: Real Truck
E450 Modification Questions
Old Jul 10, 2003 | 10:14 PM
bithead2's Avatar
bithead2
I'm taking possession of a Winnebago that is built on a E450 chassis (brand new). I'll be keeping this unit for a really long time, and may also do some towing. The GCWR is supposed to be 20,000 lbs and the GVWR is supposed to be 14,000 lbs. so I believe that means that I can tow up to 6K lbs, no?
Anyway I am interested in knowing what modifications I should consider to this. A good exhaust header system is probably a must to improve power and gas mileage. But what about these things?
- Tranny Cooler and Tranny Temp Gauge
- Better Air Filter/Intake System
- Brake Buddy or SMI System
I'd like to hear opinions on these and any other modifications to improve mileage, power, or longevity of the components.
Chris
Old Jul 11, 2003 | 07:33 AM
yavapai's Avatar
yavapai
what motor..V10 ? i think your GCWR will be higher than 20K,but i'm not sure on the E series.14000 lb GVW is pretty decent.i'm just guessing that your limiting factor would be your gross combined and you need to find that out.on a class A 450 motor home the GVW is 26000 and with a 15700 GVW max trailer wt. is 10300 according to the brochure and the V10 450 reg. chassis cab auto with 4.88 axle is 24000gvw 5.38 axle 26000gvw.
Old Jul 11, 2003 | 08:19 AM
bithead2's Avatar
bithead2
I did a little more reading. The Winnebago brochure says that there is 3500 lb towing capacity and a 350 lb tongue weight hitch. Not sure if this will be enough to tow my 4Runner.
Anyway, still interested in knowing what engine/tranny mods might be worth looking at.
Chris
Old Jul 11, 2003 | 12:47 PM
yavapai's Avatar
yavapai
o.k. but are you going to tell us what motor/engine/powerplant you have in that rig ?
2015F450
Jan 23, 2016 07:17 PM
JockD
18
Jan 16, 2015 12:12 PM
douglasatkins50
Large Truck
13
Dec 12, 2014 09:35 PM
douglasatkins50
Feb 1, 2014 10:03 AM
nojoke327
Nov 14, 2013 09:06 AM
