04 expy still stalls
Old Jul 25, 2014 | 06:05 PM
bdog813's Avatar
bdog813
I changed the up stream hose to the dpfe sensor replaced the fuel filter and changed the iac valve what am I missing family? Gimme some opinions please
Old Jul 26, 2014 | 11:40 PM
alloro's Avatar
alloro
Stalls under what conditions?
Old Jul 26, 2014 | 11:57 PM
bdog813's Avatar
bdog813
Mostly low rpms or idling. Outside temp is not a factor nor does the truck have to be hot. Im thinking the egr valve or tps but not sure
Old Jul 27, 2014 | 12:12 AM
alloro's Avatar
alloro
Have you had it scanned for trouble codes?
Old Jul 27, 2014 | 05:59 AM
bdog813's Avatar
bdog813
No. The check engine light is not ON so I would think no codes would be produced. Am I wrong?
Old Jul 27, 2014 | 10:43 AM
alloro's Avatar
alloro
Not all codes turn on the CEL and there is also this thing called pending codes. Pending codes are set but require multiple trips for them to be moved to the actual trouble code category and turn on the CEL. If the conditions that set a pending code don't happen on the second trip, then the pending code is cleared and the cycle starts again.
f150_in_rock_hill
2004 - 2008 F150
29
Jan 18, 2010 03:19 PM
408w
May 22, 2009 01:05 PM
8inav
May 21, 2009 08:06 PM
Robert porovich
Oct 15, 2007 11:40 AM
