idle problem???????
Old Apr 29, 2002 | 10:17 PM
doxslayer's Avatar
doxslayer
idle problem???????
i own a 95 f-150 and it has an intermitten problem with the idle.it will idle high around 1000 to 1200 .i have a standard transmission and i monitor the rpms and my shift pionts with my tach.when it acts up my truck tachs up in every gear faster.at 60 mph in 5 gear i'm doing 3000-3200 rpms.i have replaced the map sensor,throtle air bypass valve,coolant temp sensor,o2 sensor,and the air temp sensor.it seems to be running rich by the residue in the tail pipe.i need some help my milage sucks 10-12 mpg?what is average mpg for a302 with 136000 miles on it?
Old Apr 30, 2002 | 09:40 PM
fordtruckman79's Avatar
fordtruckman79
idle problem???????
I have similar problems with my truck, but it sounds like you might have a faulty catalytic converter. also you may want to check the idle air valve.
Old May 1, 2002 | 08:07 PM
Wilber15's Avatar
Wilber15
idle problem???????
If it ain't broke.....change stuff till it is!
don't know if this is it, but TPS(throttle position sensor)......
Old May 1, 2002 | 10:06 PM
MR GOODWRENCH's Avatar
MR GOODWRENCH
idle problem???????
sounds like a vaccum leak to me, start by checking vaccum lines, if you don't find anything there, it could be a plenum or intake gasket, not knowing what engine, I can't get too specific.
Old May 2, 2002 | 01:42 AM
doxslayer's Avatar
doxslayer
idle problem???????
it is a 302 with 5 speed standard tanny. I have spray 3 cans of carb cleaner on and around engine with no idle change?its been in the shop 3 days now and they are stumped.
Old May 2, 2002 | 12:45 PM
tmcalavy's Avatar
tmcalavy
idle problem???????
If you've got black soot in your tailpipe and its really eating gas, have the fuel pressure regulator checked...costs about $20. It that ain't it, maybe the throttle position sensor could cause the idle surging.
Old May 2, 2002 | 03:43 PM
460lover's Avatar
460lover
idle problem???????
It probably is a vacuum problem. When I bought my first truck ('88 F150 std cab long bed with a 351), it idled fine, but I got only about 6 mpg. It was because the map sensor wire had been pulled off the connector, it idle normally after that and the mileage more than tripled.
Old May 2, 2002 | 07:49 PM
kwing's Avatar
kwing
idle problem???????
Blow into the vacuum line from the MAP sensor. If there is any blockage at all it will affect how the MAP sensor reads atmospheric and manifold pressure. Check all the other hoses at the central vacuum T for contamination and ensure they pull vacuum when disconnected. Cheers.
kw
Old May 2, 2002 | 08:01 PM
Justin89's Avatar
Justin89
idle problem???????
