Sagging in the middle?
Old Jul 24, 2014 | 11:25 PM
sseebart's Avatar
sseebart
I've seen this on many older trucks--don't think it's an optical illusion. The gap between the bed and the cab is smaller at the top than the bottom, making the truck look like an old worn-out horse.
What is the cause of this and how can I correct it? I find it hard to believe that the frame itself has actually sagged.
~Steve
Old Jul 24, 2014 | 11:36 PM
BruteFord's Avatar
BruteFord
Worn cab mounts, notice in your pic that the back of the cab is lower then the front of the bed.
Old Jul 24, 2014 | 11:44 PM
Faber's Avatar
Faber
sagging in the middle
I've been doing that for about 5 years now....
Old Jul 24, 2014 | 11:49 PM
37 Ford guy's Avatar
37 Ford guy
His truck is a "wrong bed" and the body lines never lined up from the factory.
As for why it appears to be sagging, definitely check the rear cab mounts as the rubber parts may be completely flat or rotted away.
Old Jul 25, 2014 | 12:03 AM
rusbukt's Avatar
rusbukt
That truck also looks like its been hit and has pulled the the bottom corner of the bed backwards.
I held a ruler up to your picture, along the bottom of the cab and back to the front of the rear tire, and it actually looks pretty straight. Except for where the bed got pushed in.
Old Jul 25, 2014 | 08:08 AM
Blackwaterforge's Avatar
Blackwaterforge
X2............
Old Jul 25, 2014 | 09:12 AM
sseebart's Avatar
sseebart
Thanks, everyone. I've looked at the cab mounts, but only to check for rust. They're solid, but I didn't inspect the rubber. I'm assuming I can replace the rubber without removing the cab completely?
And yeah, there's a dent below the hole where there used to be an auxiliary fuel tank. Not the only dent on the truck, either! Gonna start work on the body this fall.
~Steve
inconquerable
Oct 6, 2016 08:12 PM
fordf350man
Aug 20, 2015 06:46 PM
coldy12
Jun 24, 2015 08:25 PM
LeoJr
Feb 23, 2012 08:22 PM
Brakefade
May 28, 2001 11:47 PM
