Yeah I know they are ss and that they are hard to find. I referred to them incorrectly. Just want to find some in the forum if I can
Chill Bud. Bill just put that out so the next guy on here would know. Do ya
have enough posts to use the want adds on here? Maybe check ebay and pick n pulls also.
They are rare as hens teeth as Bill would say. What
shape are yours in? A good trim and body man can do wonders. How
about some pics of what ya got or more info?
Bill can I get an illustrated view of the trim parts so I make sure I remove them properly without damage. Haven't found the pieces yet but want to be sure I do it correctly when I do. I'm guessing that the pieces in the rubber can be cut out with a razor knife. The large piece just above the bed looks like it bolts on from inside the cab. Please provide the info on the clips that hold this piece in place also. Thanks
It only shows one clip (C1TZ-6642487-A)...for the lower moulding, doesn't show the (7) #10 -24 nut and washer (354397-S100) that are listed in the text.
Bill if I'm looking at the sheet metal illustration correctly the part numbers 42206 and 403A60 might be the only sheet metal differences in the two cab designs. I didn't forget the trim, weatherstripping or glass. I'm just thinking about sheet metal. Can you confirm?
Besides the back of the cab, the entire bed is different as are the doors.
