death wobble help!
Old Jul 24, 2014 | 09:36 PM
bab350's Avatar
bab350
death wobble help!
my truck is having a bad death wobble problem almost everytime I get above 30 mph or so its an f350 with the dana 60 front end. not 100% in year since its a body swap with an f150 body, I believe it is an 88 to 91 f350 chassis and it has the 7.3 idi. It has 36 inch tires on it now, before it had 35s and it only wobbled 2 times both were going around a right turn on a rough road. now with the bigger tires just about everytime I get above 30 its start to feel like it wants to go. if I am turning to the left it stops trying to do it but he slightest turn to the right and you cann feel it trying to start up the wobble. I have repaced all tie rod ends, steering gear, hub bearings and wheel seal on passenger side, and all new shocks. and it is still doing it. I have some play in my steering wheel still could that have something to do with it? any helpor ideas are greatly appreciated
Thanks
Old Jul 24, 2014 | 10:03 PM
dfletcher's Avatar
dfletcher
Trailering
I have a similar wobble at about 45 to 55. I have been told it is the universal joints, which i will be fixing very soon.
Hope that helps
Old Jul 24, 2014 | 10:09 PM
bab350's Avatar
bab350
mine are tight there is no ply in them that was something I looked at before replacing all the things I did. Im just kind of at a dead end at the moment. but thanks I may mess them some more and see if I missed something with them
Old Jul 24, 2014 | 11:51 PM
White 97 xlt's Avatar
White 97 xlt
It won't necessarily be play, more likely tight (frozen bearings (rust/dry) in the joint). The frozen/tight u-joint causes a whipping action when it can't move as it should.
Old Jul 25, 2014 | 12:05 AM
BruteFord's Avatar
BruteFord
U-joints? The U-joints aren't turning unless the hubs are in.
OP Are the new tires knobby and on bigger wheels?
When I bought my 87 F350 it came complete with a death wobble. The 31s it came with were toast, I put on 37s with dynabeads, no more death wobble.
Since your issue is very speed sensitive I'd look at the tires. Most traditional death wobbles are initiated by a bump.
You have a king pin 60, the upper bushing/spring is often a culprit of the death wobble. Even if the bushing isn't worn the spring is too weak, I've read of people fixing this by putting a washer or two on the spring to tighten it.
Old Jul 25, 2014 | 04:12 AM
tjc transport's Avatar
tjc transport
i ain't rite
OP Are the new tires are knobby on bigger wheels?
this is exactly how i eliminated the death wobble in my 88
Daniel Garman
General Automotive Discussion
Dec 6, 2015 11:09 PM
Gear619
Mar 2, 2015 11:07 AM
Brian92390
Oct 20, 2014 04:29 PM
daved366
Aug 1, 2009 11:01 PM
GasMonkey
Sep 22, 2004 11:26 PM
