4 bbl intake
Old Jul 10, 2003 | 06:04 PM
serving_time's Avatar
serving_time
4 bbl intake
That offy intake that i hear so much about, I understand that it's in the PAW catalog. What is the price on that? Is it water heated or not? And is the 500cfm the best carb to mate with it?
Old Jul 11, 2003 | 09:06 PM
willowbilly3's Avatar
willowbilly3
4 bbl intake
I ordered one from PAW once and it was on back order forever. I finally gave up. A 500cfm should be plenty but you might get by with a 600 if you are doing some head work and running a bigger cam I had toyed with the idea of finding a Quadrajet off a small GM V8. The smaller primarys would give you more low end and maybe better fuel mileage. I know these carbs aren't everybodys favorite but they are pretty simple and most of the things that go wrong with them are external like the choke operating mechanisms. You should find one of those spacer plates off an early 60s car which the coolant ran through for carb heat. I think Clifford used to sell them
Old Jul 14, 2003 | 01:48 PM
thrakkor's Avatar
thrakkor
4 bbl intake
Offy DP at Jegs for 200 bones.
www.jegs.com
Old Jul 15, 2003 | 05:11 AM
Torque1st's Avatar
Torque1st
Posting Legend
4 bbl intake
You can warm your intake air up instead of heating the carb. I run a 70F intake air temp that keeps the fuel vaporizing good.
trucker01
16
May 10, 2014 09:23 PM
bbfan
May 26, 2006 06:19 AM
fordeverpower
Jul 1, 2005 05:17 AM
rusty70f100
62
Jul 28, 2004 05:43 AM
DFB2004
13
Sep 7, 2002 12:01 AM
