Spindles
Old Jul 20, 2014 | 10:21 PM
Shadowrider123's Avatar
Shadowrider123
Spindles
I just acquired a super nice 64 F100.
I want 5x4.5 front disc brakes.
I only find kits for 48-56 F100s in 5x4.5.
If I mill a 48-56 spindle to accept a .859 in kingpin will it bolt to my 64 axle and steering?
My truck has a 57 rear end and I have a set of 65 Mustang axles for it, so I just need to figure out the fronts.
Thanks
Old Jul 21, 2014 | 07:32 AM
FortyNiner's Avatar
FortyNiner
Your question has an answer somewhere between this forum and the 61-66 group. Bumping to the top.
Old Jul 21, 2014 | 09:04 AM
AXracer's Avatar
AXracer
I don't know with any authority about a 64, but I suspect there would be more involved than just reboring the king pins, like king pin inclination, spindle boss location and spacing, steering geometry. If no one makes a kit with your desired spacing for your truck and you must have disk brakes, seems it would be a lot easier to use a kit with a different spacing and redrill the hubs and hats to the desired lug spacing, or use adapter spacers to change the pattern.
Old Jul 21, 2014 | 04:09 PM
Shadowrider123
Redrilling is probably the easiest route.
You never know, the spindles may be a direct swap and with the number of front clips going under these trucks there are plenty of them around.
5x4.5 has a lot more wheel options than 5x5.5.
foolish63
22
Apr 17, 2017 03:51 PM
my 66
Jun 7, 2011 05:11 PM
tatonka
Feb 16, 2006 07:56 AM
outacontrol
Jul 18, 2003 06:48 PM
1950t
Jul 2, 2003 06:37 PM
