rebuild kit?
Old Jul 20, 2014 | 09:52 PM
86f150longbed!!'s Avatar
86f150longbed!!
rebuild kit?
so I got my 1986 f150 today it has the 4.9 in it and the feedback carb (I think) and it leaks oil really bad and I want to rebuild the engine but I don't know what kit to buy. and I kind of have a small budget
Old Jul 20, 2014 | 10:23 PM
cajohnson's Avatar
cajohnson
I'm a Freshman user on this board too, but I've been doing vehicles for a long time. If I may, let me suggest that you hold off jumping into a rebuild until after the engine's true condition is better known.
Granted, I don't know anything about your truck (congratulations, BTW), but sometimes what appears to be an ugly situation turns out to be not nearly so serious. Regardless, even if it does need a rebuild, it's best to know what is actually going on so you have a better idea of what to look for while the engine is apart.
What's it actually doing, and where is the oil coming from?
Old Jul 20, 2014 | 10:59 PM
86f150longbed!!
valve covers, side covers, oil pan, rear main seal (I think) and every where else I even have oil in my air breather
Old Jul 20, 2014 | 11:01 PM
86f150longbed!!
and thanks
Old Jul 20, 2014 | 11:19 PM
Rusty_S's Avatar
Rusty_S
Oil in the air filter is generally caused by a bad PCV valve allowing oil mist to find its way into the air filter housing. I never been able to stop it completly changing the PCV but a new PCV has reduced the amount of oil soaking into the filter for the PCV.
Old Jul 21, 2014 | 01:35 AM
86f150longbed!!
Thanks rusty
Old Jul 21, 2014 | 07:38 AM
Gary Lewis's Avatar
Gary Lewis
I agree with Chris, and I rep'd him for his statement. Just because an engine leaks oil doesn't mean it is worn out. It means that the gaskets are leaking. Only something like a leak-down test can ascertain the condition of the internal parts.
I would thoroughly clean the engine and engine compartment. Usually that requires several cans of engine degreaser and a few trips to the car wash, but you really need to get it clean. Then determine what is causing each leak. Sometimes a leak can be slowed, if not stopped, by snugging up the bolts. But other times it will require removing and replacing the gasket, although you might want to wait on that to see what the internal condition of the engine is.
To do that you should do, or have done, a leak-down test. That will tell you a lot about the rings, valves, and head gasket. If that says the engine is badly worn then turn your thoughts to rebuilding, which will cost at least $1000 and probably almost twice that much. But, the 300 six is one tough engine so you may find that it'll serve you well in its current condition if the leaks are stopped.
Old Jul 21, 2014 | 10:40 AM
86f150longbed!!
thanks gary, next thing to do is a major engine cleaning btw it burns oil real bad to. how should I check what that is?
Old Jul 21, 2014 | 10:58 AM
Gary Lewis's Avatar
Gary Lewis
If the rings are bad then a rebuild is necessary. But sometimes it isn't the rings but the PCV system that is causing the crankcase to become pressurized and force oil into the cylinders as well as past the gaskets. So check out the PCV system as well as clean.
Old Jul 21, 2014 | 01:31 PM
arctic y block's Avatar
arctic y block
Does it blow a big huff of smoke when ya first start it for the day? Than clear up some after it warms up? This would be valve guide seals and
doesn't generally denote an engine overhaul either. Again this is just a gasket or seal and doesn't mean the engine need a complete overhaul.
The leak down test or a simple compression test can and will tell us a lot.
Most likely all ya really need is some new gaskets and seals. That is a very long service engine and can go several hundred thousand miles.
Old Jul 21, 2014 | 05:31 PM
86f150longbed!!
you hit the nail on the head bub everyday if huffs a cloud of smoke lol
Old Jul 22, 2014 | 11:55 AM
KsCop's Avatar
KsCop
If you are talking a true rebuild, you're also talking machine work; clean and check block, bore / hone cylinders, cylinder head work, deck block and head, maybe even line bore and then there is crank and cam work. Once that is done, the 'rebuild' starts..
On the other hand, if you are just replacing gaskets and seals; there are plenty of gasket kits out there.
I'm a big fan of do it once and do it right; I'd hold off on the rebuild until you have the funds and know what the real issues are.
That said; I have a 4.9 sitting in the bed of my truck that I'm just getting ready to rebuild... I must be crazy..
Old Jul 23, 2014 | 02:24 AM
86f150longbed!!
So i found out today i have to replace like every gasket on the engine plus it most likely needs piston rings. It smokes like a diesel when i start it and when im giving it gas while driving
Old Jul 23, 2014 | 07:39 AM
Gary Lewis's Avatar
Gary Lewis
While it is probable that you need to replace the rings, it is still possible that a plugged PCV system can cause it to burn oil. I would check things out as previously suggested before tearing into the engine. A rebuild will cost more than $1000 if you assemble the engine.
Old Jul 23, 2014 | 08:31 AM
1986F150six's Avatar
1986F150six
Also, since you have just aquired the truck, it is possible the oil needs replacing. Since Summer, try using a 15W40 [i.e. Rotella] and a good oil filter [Motorcraft Fl-1A] and see if the smoking lessens.
The recommended weight of oil is 10W30, but with wear, clearances increase and the thicker oil can help. By the way, the oil and filter change requires 6 quarts.
