One Key System?
Old Jul 20, 2014 | 11:25 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Originally Posted by Rusty_S
Little off topic though but I went to the local antique chevrolet junkyard for a new ignition switch for my 63, got one but the guy didnt have a key so I drilled it out once I got the lock tumbler out I saw it had the same key code engraved in it as my orignal key. I could have used the key on my car to get that lock tumbler out. What are the odds of something like that happening.
Im sure its more common with model T`s as I think they had something like 4 or 5 different keys for all their cars.
A friend has a box full of ford keys. It's quite rare for him to run across a ford car/truck from the mid 60's to early 90's, that he can't (eventually) unlock the doors/ignition.
Same guy also took the door and ignition locks from an 86 F350 crew cab, 91 "Super Chicken" (T-bird super coupe) and 95 F150, and had a locksmith set them up to use the same key. He got tired of always grabbing the wrong set of keys when trying to go somewhere.....
Naturally, he lost the key, and was kinda stuck. By stuck, I mean the only vehicle he could drive, was a Cobra replica, except it was blocked in by a couple of the others that he lost the key for....... And, that was one key he didn't have in the box.......
Old Jul 20, 2014 | 11:54 PM
Ranger80's Avatar
Ranger80
Well if it's any comparison, when one of the door locks broke on my '80, I pulled one from an '85, which used the oval key. That key also worked for the glove box lock that I pulled from the center console of an '89 Bronco, and the glove box lock on my '92 that I never had a key for.
Old Jul 21, 2014 | 07:50 AM
Gary Lewis's Avatar
Gary Lewis
So, you have one door lock that uses the ignition key and one that uses an oval key? And the oval key also does the glove box. Right?
Old Jul 21, 2014 | 08:17 AM
Rogue_Wulff
The glovebox has always used a round key. Dad's 74 came with 3 keys, the square head key for doors/ignition, the round head key for glovebox, and a smaller key that fits the bedside toolbox.
Old Jul 21, 2014 | 01:00 PM
86Stepside's Avatar
86Stepside
I had a similar situation to this back when I had two trucks. I used to be friends with someone who is a locksmith, and I had him key both trucks to the same key. Both trucks had doors replaced with ones from the '90's that used the 10 cut keys. His solution was to cut the key on one side for the doors, and the other side for the ignition.
pic of key in ignition
Sticks out a hare, but works just fine.
Old Jul 22, 2014 | 03:34 AM
Ranger80's Avatar
Ranger80
Correct, except the ignition lock also failed so it uses a different key now too. The original ignition key still unlocks one door. Same situation with my '92, I had to replace the ignition lock in it too. One of these days, since the '92 is being converted to appear as an '80/'81, I'll probably use '80 style locks in both of them and either have them both keyed the same, or have one side of the key cut for one truck and the other side for the other truck.
Old Jul 22, 2014 | 07:32 AM
Gary Lewis's Avatar
Gary Lewis
I would swear that I posted on here last night, but I sure don't see it. My guess is that the gremlins taking the servers down ate it.
Anyway, I got two responses from dealers who have the 80 ignition and door lock sets. One wants $52 for a set and the other wants $65. I was inclined to go with the $52 one until I remembered two things: First, I've been promised a locking hood release with the ignition, glovebox, and door tumblers. Second, I'll have a security system tied into the power door locks so will rarely use the door key. Given those two things I think I'll wait and see how it comes together.
But, thanks for the help clarifying the situation. I think we can now safely say that in 80 Ford used a different door lock than was used in 81-86, and that door lock used the same key offset as the ignition key. And, some of those sets are still available.
Old Jul 22, 2014 | 02:31 PM
FoxFord33's Avatar
FoxFord33
I do consider myself an expert on this subject, but only for the post-89 or so vintage. Did you read my story about replacing my ignition? It is for a later date, but it looks like it's a similar setup. Using one key for Ignition and Doorlocks after replacing the Ignition Cylinder - Ford Truck Enthusiasts Forums
Old Jul 22, 2014 | 04:45 PM
Gary Lewis's Avatar
Gary Lewis
Who are you???? Oh yeah, you are Chester! (I'd better confess now as I called you that Sunday morn and you could tell the age of those in class - the old ones laughed. Well, all but the old, elderly-type, guy that was taking the prayer requests. It went right over his head but, judging by how little hair is on that head, I'm guessing lots of things have been whizzing right on by.)
And, reading the post you linked to....... to which you linked, I can believe it. Wow! What a lot of detail. But, just 'cause you are laid up doesn't mean I'm going to relinquish my crown - Master of Trivia. But, I'll gladly share it with you.
So, is there any chance that the ignition tumbler from, say, a '96 Bronco will fit an '81 F150? I'd bet the door locks will, but kinda doubt the ignition tumbler will. (But I'd bet the tires and wheels will! )
Old Jul 22, 2014 | 05:00 PM
FoxFord33's Avatar
FoxFord33
I'd like to tell you that you could have them, but it appears that at least 2 of them are ruined!
Old Jul 22, 2014 | 05:18 PM
Gary Lewis's Avatar
Gary Lewis
Bummer! I literally looked them over Thursday morning leaving the cafe. And just a couple hours later........ Shame. But at least you three were safe - relatively.
Old Jul 23, 2014 | 03:14 AM
Ranger80's Avatar
Ranger80
'80-'91 ignition locks will work '92-'96. Not an exact fit, wiggles a bit, but the grooves are cut similar. I never tried using the newer one in an older truck but it looks a bit bigger. Door locks interchange between all. '80 and '92-'96 had the offset like the ignition key, '81-'91 had the regular oval door key offset. The only difference between the '80 and the '92-'96 is that the latter used slightly longer, 10-cut keys. Physically though, they're all the same.
Old Jul 23, 2014 | 07:41 AM
  #28
Gary Lewis's Avatar
Gary Lewis
Good to know. Still not sure what I want to do, so will probably use what I have. But, at least I now know what can be done. Thanks, all!
Old Jul 23, 2014 | 11:42 PM
  #29
Rogue_Wulff
Just for giggles, I looked up door locks at autozone and oreilly. Both showed the same part number, and the same pic. In the pic, it clearly shows a square head key, which would be correct for an 80. But they both list them as fitting 80-86, which is not quite right.......
Ignition locks claim to fit 80-91, which fits with the info posted previously.
Old Jul 24, 2014 | 06:48 AM
  #30
Gary Lewis's Avatar
Gary Lewis
And, that's what we found when we looked at door locks in the LMC catalog: 80 to 86. Yes, the lock will work on an 80, but it isn't correct.
