2004 FORD F350 6.0 HELP PLEASE
2004 FORD F350 6.0 HELP PLEASE 3 DAYS AGO MY TRUCK WAS HAVING A HARD TIME STARTING AND RUNING NOT SO GOOD WITH BLACK SMOKE SO TOOK IT TO A SHOP THEY SCANED IT FOUND THAT THE FICM WAS ONLY GETTIN 33 VOLTS NO OTHER CODES CAME UP SO I PUT IN A NEW FICM AND IT STARTED AND RAN BETTER THE NEXT MORNING TOOK IT TO GET A OIL CHAGE IT DIE WHEN I WAS LEAVING AFTER THE OIL CHANGE IT WAS LOW ON FUEL PUT SOME FUEL IN THE WENT A FILLED IT UP AND PICK UP A AEM AIR SUPPLY KIT RAN GOOD ALL THE WAY HOME. LET IT COOL DOWN PUT THE NEW AIR SUPPLY KIT ON STARTED RAN GREAT 2 HOURS LATTER DRIVING TO THE RACES IT STARTED ALL OVER AGAIN WOULD NOT START BACK UP I WAS NOT HEARING THE FICM RELAY PULLED THE RELAY IT WAS REAL HOT WHEN IT COOLED DOWN I STARTED GOT HOME IT DIED SO I GOT A NEW RELAY IT STARTED RIGHT UP LET IT RUN FOR A HOUR SHUT IT DOWN 3 HOURS LATER IT WOULDN.T START PLEASE HELP
check the three connectors to the ficm all good started ran it 4 1/2 hour went to a friends house shut it off 1 hour later would not start left it there next morning started it up drove home would not started 2 hours later put scanner on pulled up 4 codes P0603, P1000, U0105, AND U0306 I AM ABOUT TO PULL MY HAIR OUT
p1000=OBD ready test probably both battery disconnected it should be up now.
u0105=lost communication to ficm, Connections to ficm from PCM or pin's
u0306=software incompatibility with ficm communication error, where did you get the ficm ? may need to get a hold of Ed down at ficm repair .com
That's a good point the code book does say re flash and he has a aftermarket FICM that's not programed most likely , hell washed and Vacuumed I may have to take my Truck at least once a month for Flashin
2004 ford f350 6.0 no oil in the filter bowl
put a new low presure oil pump in because truck quit no codes new fuel filters so pulled oil filters very little oil got the low presure oil pump gears out the loabs were pretty tore up put the new one in all back together still no oil
do you have to prim this some way please help
