issues with starter and selenoid
Hey everyone. So my husband and I have changed his starter and selenoid on the side wheel well on his 87 f150 lariat about 4 times since may. The selenoid keeps frying and now his truck won't stop trying to turn over unless you unhook the battery cable. We went through this before but don'tdon't get why it keeps happening. It made a weird noise before it happened this time. Does anyone have advice? We need it running again asap.asap.
It's not "getting too many amps"
The starter needs 'X' power to turn the truck over.
Power (watts) is voltage times amps.
If the voltage getting through is low, the current (amps) will be high, to meet the demand of the starter.
Too much current (amps) will overheat the contacts of the solenoid, causing them to melt and stick together.
My advice?
Check, clean and tighten all connections at both ends of both battery cables.
And both ends of the starter cable.
Replace any cable that looks at all questionable.
Cranking slow at the end of a day of driving could (and likely does) mean that heat soak is causing high resistance in the starter itself.
This is much more common with headers than manifolds.
My advice?
The Made In China Junk and/or Made in Drug Cartel Run Mexico solenoids being dumped in this country of recent are GARBAGE -- evidence the fact you've replaced these and the starter four times...............
Something is "sticking" in your ignition circuit and the probabilities are high it's that solenoid you've replaced repeatedly (what we call a "plunger" hang internally)........the other candidate is surprisingly your alternator -- could be shorting internally and playing with the battery terminal on the solenoid (starter relay)-- getting errant current at the solenoid----a "field" here can move that plunger in your solenoid and keep that starter circuit sticking.....
From the perspective of someone who has been dealing with various charging circuits for 40 years there is no evidence.
My advice?
My advice?
