Headlight Restore
Old Jul 19, 2014 | 09:33 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Headlight Restore
Did my headlight lenses with 3M Headlight Lens Restoration Kit 39008. Works EXCELLENT! Did my truck and a TDI Beetle, and still have enough to do another vehicle for $15.00.
Old Jul 19, 2014 | 11:34 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
3M products usually rock, thanks for guinea-pigging it. I used a Mother's kit and while it helped, the lenses had crazing that was too deep to fix. Did my Aerostar same time, looked good but got hazy again in about a year.
Old Jul 20, 2014 | 07:57 AM
Whitey Ford
The instructions said 3M has a product you put on a couple times a year to prevent that from happening. On the first 500 sanding pad you could finally sand below the deep scratches and watch them disappear. I did however have a few that remained. I took my time and made sure I got the whole lens really good on each step. It does really work!
Old Jul 20, 2014 | 08:11 AM
Pikachu's Avatar
Pikachu
I used a kit a detailer friend of mine had given me that came with the cleaner, sandpapers, and sealer. When I got to the sealer and opened it I recognized the smell of it. I'm about 99% sure is was marine exterior varnish. It was kind of amber in color and took about the same time to dry as varnish. It would make sense to use something like that since it's got a lot of UV protectants in it and holds up well.
Old Jul 20, 2014 | 03:03 PM
nlemerise's Avatar
nlemerise
Wet sand with 1000 grit, then wet sand with 3000 grit, then use Meguiars Polish and buff out. They will look as good as new.
Degreaser
Apr 16, 2013 01:28 PM
Gage2502
Jul 7, 2012 09:49 PM
Whitey Ford
Feb 22, 2012 08:42 PM
MX_Fyrcaptain
18
Jul 30, 2011 10:56 PM
RandB
Aerostar
Sep 28, 2007 11:17 PM
