This morning, I pulled the springs in my 79 Bronco to replace bushings. I found that the front left hanger has the inboard hole has some fretting corrosion from the bolt being loose at one point.
I'm having a hard time finding the part, though. JBG has them, but I'd like to compare some options; I'd prefer to keep the same stock holes and theirs needs to have new holes drilled.
Does anyone know if the 1980+ are the same part? I can find those stock units for sale at several places.
Does anyone know if the 1980+ are the same part? Not the same.
D8TZ-5775-A (replaced D3TZ-5775-B) .. Rear Spring FRONT Hanger Bracket / Obsolete ~ No Ford dealer or obsolete parts vendor has any.
1978/79 Bronco / 1973/79 F100/150 4WD except Super Cab / 1973/79 F250 2WD except 8,100 lb. GVW & Crew Cab / 1977 F250 4WD from serial number Y20,001 (not a High Boy) / 1978/79 F250 4WD ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- EOTZ-5775-C (replaced D3TZ-5775-C & D8TZ-5775-B): The rear spring REAR hanger bracket used with all of the above .. is the same as misc 1980/96 F100/350 & Bronco.
