Ac blows hot but defrost blows cold
Old 07-16-2014, 07:43 PM
velocicurtis's Avatar
velocicurtis
velocicurtis is offline
My AC blows hot air, like heater hot, but the defrost on cold blows cold air. At first the AC would cut out at low rpm's (stop sign or red light) and cut back on, now its nothing. But the defrost blowing cold, enough to fog up the windshield, tells me its not the compressor or freon. Any ideas?
Old 07-16-2014, 10:07 PM
1saxman's Avatar
1saxman
1saxman is offline
Sounds like a blend door problem, which would include a problem in the head unit. It could be opening the door to the heater core in the dash register position. Can you use the temperature **** to make the defroster air warm?
Old 07-17-2014, 10:39 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
blend door is controlled by electric motor and adjustable from cold to hot. It mixes the air to get correct temp. Common for door, control arm, or gear box to strip out. location is under the radio, above the transmission hump. Remove plastic panels for access.
tgspencer
08-09-2015 06:25 PM
CharlieBravo
1997 - 2003 F150
04-26-2010 10:20 PM
ckeezer
1983 - 2012 Ranger & B-Series
09-21-2008 10:25 PM
mgmoore7
09-12-2006 07:01 AM
MRB068
05-13-2002 06:57 AM
Quick Reply: Ac blows hot but defrost blows cold
