Finally
Old Jul 17, 2014 | 08:42 PM
Tedster9's Avatar
Tedster9
The oil bath is probably better at filtering air than a paper element when you get down to it.
Maybe they aren't the best for 1/4 mile but have nothing to do with normal acceleration. They are kinda hard to find, even - because so many people ditched them.
Old Jul 17, 2014 | 11:26 PM
Shadowrider123's Avatar
Shadowrider123
I think the truck 292 was rated at 130 gross hp.
That's pretty weak by todays standards, I just don't see this truck lighting up the tires unless I swap in a set of 5.38s like my old CJ had.
Old Jul 18, 2014 | 12:50 AM
Tedster9's Avatar
Tedster9
Might be "weak" by today's standards - but the original post mentions a top speed or difficulty to reach even 55, that indicates a problem having nothing to do with design of the Y block.
Old Jul 18, 2014 | 09:20 AM
Shadowrider123
Ted that doesn't necessarily indicate a problem. It could just be geared low.
I need to get a tach on it and see what rpm Im running.
Old Jul 18, 2014 | 11:27 AM
Tedster9's Avatar
Tedster9
But then that wouldn't be a performance issue related to the engine, which was my point.
Sent from my iPhone using IB AutoGroup
Old Jul 18, 2014 | 04:53 PM
66f100project's Avatar
66f100project
Originally Posted by Shadowrider123
I drove this baby home today.
top speed was about 55 mph.
Did you check the engine compression? Also the fuel pump rate of delivery?
Old Jul 18, 2014 | 05:58 PM
arctic y block's Avatar
arctic y block
Brake dragging maybe? It don't take much to pull this little engine down.
Something just aint right though as it should do all of 80mph comfortably.
Old Jul 18, 2014 | 10:34 PM
shortwide's Avatar
shortwide
Yep...I agree.
My first year y-block (239) would run 80. It wasn't overly thrilled doing it, but it would do it without too much trouble.
Old Jul 18, 2014 | 10:36 PM
Shadowrider123
I think the speedo is off, Im going to check it against the GPS.
I was on a stretch of road doing 45 and cars were whizzing by me at a pretty good clip, normally at 45 Im moving with traffic on that road.
I drove the 66 this afternoon. The 352 has way more get up and go than the 292, maybe Im used to more power.
Old Jul 19, 2014 | 01:22 PM
arctic y block
The Y-Block can be an expensive engine to work on and build up. But it is so sweet when done right and can have plenty of power. Check out Johns site.
Y Blocks forever I think it is.
firemanpat29
Dec 3, 2018 09:48 AM
pineconeford
13
Dec 30, 2015 04:26 PM
Texas Killa
1961 - 1963 F100 Unibody
May 17, 2013 12:42 PM
59flatbedford
91
Aug 29, 2011 02:17 PM
bulimic.cannibal
Aug 4, 2008 08:10 PM
