Fuel problems?
The tach is supposed to move when cranking. If it doesn't, then that's another problem; Cam Position Sensor, or CPS. Motorcraft or IH brand only, NO OTHERS, PERIOD.
I'm going to x2 that you should see what level the fuel tank is showing and if it's anywhere near 1/4 tank, take a 5 gallon tank and put some more fuel into it. Then, see if it will fill up the fuel bowl. If that works, don't ever let the fuel tank get close to 1/4 tank again, unless you feel like dropping it and fixing the fuel pickup, a.k.a. "showerhead".
Mine didn't and a few others here doesn't.
There is a thread floating around about it.
That's a new one to me then. I've always used a no tach movement as a bad CPS diagnosis. But I guess that 97 IS the weird year when it came to different things like a federal and california version...
Okay guys I was able to make it to the truck late last night. So I tried checking fuel pressure at the shrader valve but I could not get my gauge on it so did not get to check. But tried cranking the truck over and it did not fill filter bowl up. Also I noticed when I cut key on the wts light came on and cycled but was really fast like 5 sec, it has be around 80 here? So I checked all the fuses under dash and they were good. Then was checking the box under hood and found #17 blown witch was a maxi 30 for the icm or pcm. Replaced it but as I said then I tried again and the batteries for to weak to get it to turn over good. I will be charging battery today and any recommendations on the next step I should to w once I reinstall battery s. Thanks in advance
You also need oil in the HPOP for the injectors to fire. There is a plug on the driver's side of the reservoir at the front of the engine. Oil should be approximately 1/2 to 1 inch below the top of the reservoir.
There is no pump on the frame unless some one put in a electric fuel system. From the factory these things came with a mechanical pump on the top of the motor. The pump is a 2 stage pump that first bring low pressure fuel from the tank to the fuel bowl then steps up the pressure to fill the injectors. You need a minimum of about 25psi to make it run. 50+ to run well
#29
