E4OD MLP/TR sensor
Old Jul 16, 2014 | 07:57 PM
94302f1504x4's Avatar
94302f1504x4
Question E4OD MLP/TR sensor
I have a 1994 f150 5.0 4x4 with a E4OD trans. I replaced the MLP/TR sensor with a 1995 sensor for an E4OD. Truck starts but idles and runs extremely rough. Wonder do I need to maybe reflash the ecu or what?
Old Jul 16, 2014 | 09:06 PM
rla2005's Avatar
rla2005
There is no ecu "flashing" on this vintage Ford. Replacing the TR sensor has no bearing on the engine performance or the idle quality.
Old Jul 17, 2014 | 07:11 AM
94302f1504x4
What do you think it might be? It'll start up fine about the first three times but idle extremely rough enough to shake the truck side to side. And then eventually won't start up it'll just crank
Old Jul 18, 2014 | 08:15 AM
rla2005's Avatar
rla2005
How old are the plugs, wires, cap & rotor?
Is the Check Engine Light On? Regardless if it is or not have you ran the KOEO tests and CM code display?
When it will not start have you checked for spark? Same for fuel pressure?
Old Jul 18, 2014 | 08:41 AM
Conanski's Avatar
Conanski
Yeah you need to pull the codes and check fuel pressure, that will point you in the right direction to solve the problem.
SMS888
Jan 23, 2019 11:27 AM
Cdy1
Oct 20, 2008 07:12 AM
bradleygt302
Mar 8, 2004 06:29 PM
rancherman84
Jan 17, 2004 03:09 PM
s_laviolette
Nov 19, 2001 03:23 PM
