Ford Warranty Issue
I thought that due to the fact it is a major emissions component that the DPF was actually forced by the EPA to be warrantied to 150,000 miles.
At least I heard that somewhere, could be wrong though, it was a while back so........
answer
This one you send it in.
I would also look around your area for large trucks stops or large diesel repair shops.
I've seen such a setup at Minuteman Trucks, who happens to be a site sponsor. The equipment uses compressed air to clean out the pores in the filter. I believe they charge about a thousand bucks to clean a DPF.
Lots More on clean
But yes you could do something cheap with a pressure washer that would give you 50 percent of the same results.
Big Diesel rigs have this done commonly. It just something that has to be factored in.
I don't understand why cleaning it has a bad feel to it.
This is a problem I'm concerned about as I work from home and much of my driving is short hops around town with the exception of towing my RV every few weeks. I know I'm heading for an impacted DPF.
It heats the DPF for 12 to 24 hours at reversed air flow. It will also report on the over health before and after the cleaning and compare it to the factory NEW spec's. But yes you could do something cheap with a pressure washer that would give you 50 percent of the same results. Big Diesel rigs have this done commonly. It just something that has to be factored in. I don't understand why cleaning it has a bad feel to it.
OK
On the cleaning sites read the write up's on the process. I have not found one yet that only uses compressed air. Compressed air by it self would not be that good of a cleaning.
The ones I saw are heat and air. I did find one that uses ultrasonic water tank then air, cant find that one now. Seemed like a good idea.
But saying all that, I would be temped to simple reverse flow the system with distilled water and then see. There are many YouTube videos on this.
This one has almost zero cost except labor and time.
I don't think a cleaned system is 100 percent as a new one but if you get 80 percent of new your still money ahead.
#28
Ive got a 2011 F350 SRW. With 58,058 miles the check engine light comes on, and the truck will not finish a regen. I brought it to a local Ford dealer, and they find "no problems" the manager tells me to "drive it, its probably one of the sensors, but we aren't gonna just throw parts at it". The problem persists so I bring it to another dealer. They find that the CEL was caused by the soot filter / DPF being plugged, causing it to not be able to finish a regen. It now has 63000 miles on it.
Apparently now it is out of warranty after 60,000 miles, and I am responsible for the bill, even though it was in the shop for the problem under the warranty period.
#29
I contacted Ford customer service and was told too bad we didn't diagnose the problem until after your warranty so pay up. I did keep her on the phone for an hour though saying I was not happy with the outcome and I wanted a resolution. She finally hung up on me. I think we should all call customer service and tie up the line at $12.00 per hour until it equals out to the repair bill. Atleast Ford would have to pay for the customer reps time.
Good luck but i don't think you will get anywhere with Ford. They simply do not care about honoring their warranty or offering customer service and it shows.
#30
Turns out I brought the truck to a small independent shop, and after a few hours, he changed the EGT12 sensor, (1 of 4 that are plugged into the DPF unit) and Voila.....truck went into a regen. I hesitantly towed my camper to Maine and back, and logged 1800 miles without anymore CEL....(knock on wood)
