Ford Warranty Issue
Ford Warranty Issue
Ive got a 2011 F350 SRW. With 58,058 miles the check engine light comes on, and the truck will not finish a regen. I brought it to a local Ford dealer, and they find "no problems" the manager tells me to "drive it, its probably one of the sensors, but we aren't gonna just throw parts at it". The problem persists so I bring it to another dealer. They find that the CEL was caused by the soot filter / DPF being plugged, causing it to not be able to finish a regen. It now has 63000 miles on it.
Apparently now it is out of warranty after 60,000 miles, and I am responsible for the bill, even though it was in the shop for the problem under the warranty period.
too bad you are not near Texas.. you can find takeoffs here
Dpf filter
The original dealer should be able to verify that you had the issue prior to 60K miles either thru their customer service system or thru OASIS. Probably won't be in OASIS is they didn't do anything which is why I always keep my service receipts/invoices. You signed a document that authorized them to look at the truck. When you picked it up you should have signed and been given a copy of a service invoice describing your complaint/issue and the resolution if any.
Crystal
