HELP!
Old Jul 16, 2014 | 11:05 AM
NC06stroker's Avatar
NC06stroker
HELP!
Just did an EGR delete an cleaned the turbo while it was off. Put it all back together and now i have no boost, an crazy whistle when im not on the gas pedal! WTH?
Old Jul 16, 2014 | 11:13 AM
mustang_309's Avatar
mustang_309
Start looking for your exhaust leak on the up-pipes. And check everything you put your hands on. Make sure you got the MAP hose reattached.
Old Jul 16, 2014 | 11:20 AM
David7.3's Avatar
David7.3
Did you plug the VGT back in? How do you know you have no boost, the noise or just the performance, try to disconnect the battery's and reset the ecm.I have done quite a few of the 6.0 EGR delete kits and never had a problem like this, there were no rags left in the turbo or the tubes? Maybe someone else has an idea about this.
Old Jul 16, 2014 | 12:36 PM
Yahiko's Avatar
Yahiko
I am with ^^^^ on this. Time to recheck the work.
Did it all fit back together without any force?
You can't use the clamps to pull the pipes. They need
to sit in the right place to start or your going to bend
something and get a leak in the process.
Sean
Old Jul 16, 2014 | 07:32 PM
78fordman's Avatar
78fordman
Check up pipes to turbo connection. They can be a battle. As stated above, the clamp will not slide it into place.
Wyatte
Sep 26, 2016 08:23 PM
jagerbomber
Mar 1, 2013 07:09 PM
zss42002
Feb 19, 2013 03:00 PM
lakewood
Aug 10, 2010 05:30 PM
006f350diesel
Dec 14, 2007 08:31 AM
