SOOOO bright! LED lights added!
#34
Question
I've been thinking of replacing my PIAA light (one died due to poor quality control) with a light bar in the lower grill (see gallery). I've been a little concerned about snow and ice build up over the light while following traffic in inclement weather.
Would I be better served with a curved 54" light mounted to the top of my Ranch Hand guard?
Also, the light is advertised as 24". How tight is the fit in the lower grill?
#35
#36
I suggest using this item to mount the bar in the space where the plate goes
Amazon.com: Rigid Industries 40136 Front Lower Grille Bracket for Ford Super Duty: Automotive
#37
Same with the Rigid light bar, except the brackets are a little smaller on the Rigid.
#38
#40
I received my light yesterday. I'm going to take it to my Ranch Hand installers next week when my Caribou Bed Liner painted replacement bumpers get sprayed. They said they would weld on two mounting nuts to my lower bar for a rock steady mount. They will also spray the light with the same material as the bumpers. Sounded good to me....we will see.
#42
Edit: Here is mine, just ran out to take a picture. Also a picture of the Tailgater Punisher I just finished installing.
#43
#44
No problem, I hope it works out for you. I hate hearing about something I recommend is having problems for someone. Mine have been great, but Donovan had a problem with his,
Your piaa wiring should work fine. Even better if they already have a relay. Never hurts to have a relay, those these don't require one.
The great thing about amazon prime is their shipping and return policy.
#45
